Upgrading to Unlimited - ticket history
Oldjim
Resting Legend
Fixes: 63
I just thought I would document this as it has all the hallmarks of a total screw up on my line which won't stand interleaving being turned off
10:10am, Wednesday 19 Dec 2012
Provisioning of your ADSL Account Information
Pending Provisioned Service \'WBC MAX8 mb/s (ADSL1 Annex A) Standard Stability, Auto Interleaving, 448kbit/s Upstream\' added as a part of Account Change process
New Action 21CN Modify Submitted added
(via ADSL2+ Order System Interface)
Broadband product change scheduled successfully
To: Plusnet Unlimited (Contracted)
This change will take place on the next billing date, 2012-12-23 00:00:00
8:49pm, Wednesday 19 Dec 2012
An update report has been received for this account.
The broadband service is now being transferred to the 21C Network.
The transfer will complete by midnight on 22/12/2012.
3:19am, Friday 21 Dec 2012
The broadband service has now been successfully regraded to up to 8Mbit/s speeds .
Action 21CN Modify Submitted cleared
Modify order has been completed
Subject: Your broadband service has been updated
Dear Mr
Account username:
Your broadband is now running on an 'up to 20Mb' service.
Please note that during the next 10 days, you may see some disconnections to your broadband as checks determine the fastest speed your line can reliably support.
You can find out more details about our up to 20Mb service here:
http://www.plus.net/support/broadband/speed_guide/speed_basics.shtml#speedChanges
Should you have any questions, please use the help assistant:
http://help.plus.net/
Kind regards,
Plusnet Customer Support
Service Notice #149502507
Service Notification
The customer was mailed the following message to address(es
Dear Mr
Account username:
Kind regards,
Service Notice #149502506
Subject: Important information about your broadband connection
Dear Mr
Account username:
We have asked our wholesale broadband suppliers to turn interleaving off at your request.
The stability of your service may suffer as a result of turning interleaving off. If you have problems and want to turn interleaving back on, you will need to use the Broadband Fault Checker at our website - http://faults.plus.net/
Interleaving usually takes 24 hours to turn off, but can take up to 5 days to take effect.
Kind regards,
25 REPLIES 25
Fixes: 395
Re: Upgrading to Unlimited - ticket history
That's just the sort of thing making me wary of changing. Why does a simple account change have to mess with ADSL profiles ?
bobpullen
Fixes: 316
I suspect what you've seen there Jim is a the product of one of two known problems (ref: 73795/73010). The odd thing here is past examples I've seen have capped a customer's upstream. This particular order seems to have done nothing but the opposite Huh
Upstream Link Info - 864kbps
Oldjim
Resting Legend
Fixes: 63
and as expected it has mucked up my connection - see my upstream errors
Question #63653666 raised if someone wants to help
Oldjim
Resting Legend
Fixes: 63
To wrap this up - the uncapped upload was unrelated to the move as it was part of the mass uncapping so just a coincidence  Shocked
However I received this email today from padmin@peh-cronhost05.servers.plus.net; on behalf of; Plusnet Support [support@plus.net] and it seems that the system thinks that I am a new customer and this may well explain all the odd tickets raised on my account
To add -
Current line speed:
    7.15 Mb (sync speed 4864kbps)
So it looks like this was set back to default for the up to 8Mbps service
bill888
Champion
Fixes: 38
Jim, I've read this thread with interest, but I am a bit confused with what has or has not changed.
Are you saying the product change to Unlimited, did not in fact affect your ADSL line profile/parameters?
You mentioned interleaving might have been turned off early on in the thread?
You later said the upstream was uncapped by the bulk upstream uncapping programme.  Is this the first time your upstream was uncapped by the programme, or was it uncapped again because it had been uncapped previously by the programme?
I also recall when I've previously changed products from BBYW to Extra and presently Premium, there was no change to the ADSL line profile/parameters.
fwiw, I have a 6.5mb downstream, but I am on ADSL2+ (past ticket request) and upstream has been recapped to 448 kbps after experiencing problems with phone ringing.  I'm wondering if I were to change to Unlimited, whether I will end up with ADSL1 and uncapped upstream, and then have to go through the motions of getting the line parameters changed back to previous preferred settings.
ex-Plusnet (ADSL, FTTC) 2008-2023. now BT (FTTP) 2023-
Oldjim
Resting Legend
Fixes: 63
Product change - changed my Plusnet profile from about 4.2 to 7.15
I had the upstream capped because of instability and the bulk uncapping changed that - see this thread http://community.plus.net/forum/index.php/topic,109421.0.html
Interleaving wasn't in fact turned off - that was a spurious email which was wrong - I don't know how it was generated
The profile changing may have been a one off but in any case wouldn't restrict your speeds
About the uncapping this was apparently unrelated to the product change
My line is stable waiting for the upstream to be capped again only because it resynched while the phone was ringing with this result
      ADSL Link                 Downstream     Upstream
      Connection Speed       4864 kbps       384 kbps
      Line Attenuation             50.0 db           24.5 db
      Noise Margin                   3.8 db               10.0 db
bill888
Champion
Fixes: 38
Thanks for clarifying with regards to interleaving.
So looks like you have ADSL1 before and after the product change.
hmm, so as my line speed is also less than 8mb, there may be good chance my line may change from ADSL2+ to ADSL1, if the PN systems also provision my line with the same settings as your line and starts a new 10 day training period....
Oldjim
Resting Legend
Fixes: 63
That was also wrong - it wasn't reprovisioned and there was no new training period - confusing isn't it (well I was when I received it)
bill888
Champion
Fixes: 38
Tnx for the reply.
ok, I think I'll bite the bullet and change to Unlimited ADSL which would take effect later this month.
Hopefully, it will be treated like previous product changes and so there should be no ADSL profile/parameter changes to my service.
Luzern
Fixes: 9
Hi OJ! I went via the Upgrade path. inthe community site My ticket has
This change will take place on the next billing date, 2013-01-05 00:00:00
Did you, perhaps go via the portal?
Oldjim
Resting Legend
Fixes: 63
Nope
I used the upgrade path
bill888
Champion
Fixes: 38
Out of curiosity, how did you manage to obtain such detailed ticket history?
I went through the Product Change tab to change to Unlimited yesterday Sunday night.
The only acknowledgement I can find is a Pending entry for Unlimited dated 01/01/1970 in my Account Summary page.   No Order number, No emails. No tickets.   Perhaps they will start appearing later?
Fixes: 1,483
did you look at closed tickets?
bill888
Champion
Fixes: 38
Tnx Dvorak.
I just checked for closed tickets and indeed there is just one message on Dec 23 confirming my product change from Premium to Unlimited,  has been scheduled successfully.
Update Dec 25:
My product change appears to have been completed without any apparent issues this morning.
No loss of ADSL line sync. Router logs show PPP session lost and re-established.
There have been no confusing tickets since Dec 23rd, relating to ADSL provisioning.  My 6mb ADSL2+ and recently recapped upstream have not been affected.
12:50am, Tuesday 25 Dec 2012
Bandwidth usage has been reset
The Data Transfer Watch of £15.99 has been removed from this customers account due to account change.
Invoice Period changed from: monthly to monthly
The customer was mailed the following message to address(es)
Subject: Your Broadband product change is now complete
(I've not included the remainder of the message)
User account type changed from Plusnet Premium to Plusnet Unlimited (Contracted)
(Router logs show PPP session was lost and re-established at 2.45am acquiring new WAN IP address)
