Upgraded to fibre and I must say I'm.....
rogadodge
Extremely happy with the transition.
After reading so much negative feedback on this forum I did wonder if I had done the right thing. However, my worries were totally unjustified. The router(s) were delivered early at my request. The engineer arrived promptly and installation was completed quickly and efficiently.
I had 65Mb first, one dropped connection and it has now stabilized at the predicted 38Mb, without any more disconnections.
Thanks Guys, all of you.
7 REPLIES 7
Kuffdam
Re: Upgraded to fibre and I must say I'm.....
Your one of the few
picbits
If Plusnet have 700,000 customers and only a few come onto the forums with issues you can hardly call the ones that do bother to post their positive experiences "one of the few"
rogadodge
What I have noticed is that a great many problems reported are not actually Plusnet domain. By this I mean they are "Engineer did not call/was late" which must be as frustrating for Plusnet as it is for the customer.
petecov44
Quote from: doris
My line was also predicted to 38/9 I get 50/13 - sounds like you are on the 40/10 profile? because if you got 65 to start with then if you were on 80/20 you could be getting a lot more. If you are then raise it - if not then no need to do anything Smiley
A line will drop down a bit but a drop of 27mbps is a profile restriction only
Cruise85
@Doris
As stated by petecov44 , the drop in speed that you encountered does appear to be quite a dramatic one.
If you would like to DM me your details, I can certainly make sure that your line is profiled correctly and we are providing you the best speeds available
petecov44
Of course if you are paying the £14,99 then you will be on the 40/10 I think and it's £19,99 for 80/20 so if you are paying £19,99 makes sure you take Matt up on his offer Smiley
rogadodge
I'm on the £14.99 (discounted) .  So it is now at the predicted speed. I don't know what DM means ( same as PM - personal message?). And what details do you need, account name, phone number maybe? Sorry to be so obtuse but I'm really not sure.
When I first came to Plusnet I was predicted to receive 2.5Mb. After initial hiccups it stabilized around 4Mb. Then when people started switching to fibre it climbed up to 7Mb.  So I was expecting aimee initial fluctuation.
If you could let me know what details you need I will forward them to you, thanks.
