Unresolved support ticket open for more than six months - RESOLVED: after 8 mths
- Feedback
- Plusnet Feedback
- Unresolved support ticket open for more than six m...
Re: Unresolved support ticket open for more than six months - is this a record?
01-02-2009 11:35 AM
I also had another look at the overhead cables in the light of WWWombat's comments and it does look as if my line is not tensioned as much as my neighbour's line. I'll try to take another photo to illustrate this.
01-02-2009 12:08 PM
01-02-2009 12:11 PM
01-02-2009 12:31 PM
01-02-2009 1:44 PM
01-02-2009 4:40 PM
01-02-2009 4:50 PM
01-02-2009 4:51 PM
01-02-2009 5:04 PM
01-02-2009 5:22 PM
As to the drop cable question, "my" telegraph pole has no drop cable (but it does have a blanked-off conduit about a metre high at the base of the pole - see first pic). The pole on the other side of the road (with the "box of tricks" that I mentioned in post #63) does have a drop cable that goes underground, as do most of the other poles down the road. Another question to ask the BT engineer on Tuesday, I guess i.e. why hasn't "my" pole been fitted with a drop cable?
I've also attached another pic of the top of "my" pole, as requested in post #54 (sorry, just re-read the post - not sure the pic helps much, though).
01-02-2009 5:41 PM
01-02-2009 7:30 PM
Re Another pole pic, that confirms that I should have looked a bit more carefully even though I'd not only zoomed it, but saved it to disk and looked at an even higher magnification with another program, it's just the unfortunate angle of the shot coupled with the poor cable tension (and a bit limited by the picture definition).
As I said previously, I'd be wanting the overhead cable replacing through to the joint in the loft (no joint at the white box) and of course correctly tensioned.
I think Pierre is getting his terminology mixed up, the overhead "drop" wire to your house is what often gets referred to as the drop wire, it traditionally dropped down the outside of the house to enter via the ground floor. Quite a few overheads go into peoples' houses via the loft when rewiring jobs are done these days.
The "box of tricks" at the top of the adjacent pole is just the termination of the underground cable that goes down the pole and off to the exchange.
It appears that yours' and your neighbour's overhead cables go to your pole along with another cable from another nieghbour (or two) via another pole (the one on the extreme right of the cat's cradle picture). You all then go via two cables to the "next" pole where there are more incoming overheads from surrounding properties and all of you then connect to the underground cable to the exchange. The reason there is no underground cable from your pole is simply that it is more expensive to underground than overhead when only a small number of circuits are involved, unless inclement location means frequent repairs to overheads when it then becomes cost effective to go underground.
I don't think the overhead power cables are an issue, where they run parallel to phone cables they aren't really close enough (unless there were any bad joints and arcing!). Where it's close to the main cable to the exchange, it is orthogonal.
Whilst we've all been looking at the pics, you meantioned it was "breezy" and your cable was swaying about in the wind, did you get any drops in sync?
01-02-2009 7:44 PM
01-02-2009 8:07 PM
I'll see whether I can persuade the BT engineer to run a new overhead cable into the roof space and make the connection with the line to the master socket there - certainly seems to make sense to keep the joints out of the weather.
01-02-2009 8:50 PM
One thing the BT engineer MUST do at the very least, is get rid of that bit of untwisted flex!
- Feedback
- Plusnet Feedback
