Unreadble information
teknomancer2008
My billing information shows up as garbled on my mobile screen, this needs to be checked. Specifically the information of my last three bills, the information is jumbled, presented as over each other to that the bill date is printed directly under the words bill date, making it impossible to read the information.
4 REPLIES 4
Fixes: 1,662
Re: Unreadble information
Hi @teknomancer2008
I'm really sorry to see your bills aren't readable. Are you on a mobile device or a desktop/laptop computer? Also, do you have a different device you can try getting your bills on from?
198kHz
Fixes: 42
@teknomancer2008 earlier wrote:
My billing information shows up as garbled on my mobile screen...
BT technician (Retired)
Fixes: 1,662
Oops. Thanks for being my eyes @198kHz
@teknomancer2008 Do you have another device and/or a desktop/laptop?
teknomancer2008
I'm using a phone to view this, but it really shouldn't matter, it should be readable either way...
