Totally fed up with Plusnet!!
Fixes: 246
Re: Totally fed up with Plusnet!!
@Gandalf,
As I hinted, it depends on the email client being used.
If it is possible to retain email RECIEPT capability on the old account for free, it should be possible to do the following...
  • Inbound - pop.plus.net or imap.plus.net authenticated with OLD ACCOUNT
  • Outbound - relay.plus.net authenticated with NEW ACCOUNT
That is set Outbound to required authentication ... but with different credentials to the Inbound server.
Fixes: 1,662
Just discussed this with Bob and yeah that should work.
atomit
Hello
I wish - I tried that and it doesn't work.
Best
Anne
Fixes: 1,662
Hi Anne,
I can’t confirm things since I’m not in the office at the moment but that could be because there’s no email service setup on your new broadband account. If you set it up here www.plus.net/email then wait about 4 hours before trying again it should work.
Let us know how it goes.
Anoush
jelv
Fixes: 10
This has all come about because the user was given duff information when they discussed the requirement to have broadband at both places for a short period. Now they are being considerably inconvenienced.
Is there no way the broadband element can be reactivated on the old account at the new property?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
atomit
Dear jelv
Well put in a nutshell - what I am objecting to more than anything is that such an innocuous request should be such a problem for PlusNet, who are one of the largest broadband providers. There must be thousands of people who need lines installed to a new house before they move and not just on the day itself so why should this be so difficult?
This has turned into a major palaver because the guy who gave me the duff information was really trying to help when everyone else I spoke to said "computer says no". This is the fault of PlusNet's very limited box-ticking support systems - otherwise I have found the people in support competent and helpful, just too few of them to answer the phone before 30-45 minutes and rubbish systems back-up.
I have to say that my problem is nearly fixed but I did not get the support by ringing, emailing or chatting online. I had to write a ranty message to the PlusNet community forum and then it got escalated and all sorts of people made valuable suggestions. Surely such a simple problem should not have to take several weeks to solve but having to cry for help outside the support system!
shutter
Fixes: 67
@Gandalf ..... Some good points made in that post.... perhaps the Management & Team Leaders should take note of where they are not performing as expected by the customer,... ( although they may be "ticking the boxes" for the company ) ...
Fixes: 1,662
Whilst it's technically possible to add the components back on to a downgraded account, it requires a lot of manual work with potential for things to go wrong. Plus, an existing contract itself can't be moved between accounts.
The above workaround will mean that your email service is free of charge and you'll be able to send mail via mail client for as long as you have an active broadband account with Plusnet.
If you ever decide to move your broadband services away, there's the option to pay for your email service.
Anoush
atomit
Or simply move everything elsewhere and accept the change in email address. I assumed that it would be easy to move my email address to the new account because I was told I could and because everything used to be so easy with Plusnet but it ain't the case anymore so I'll probably just shift to a provider that gives proper service.
Fixes: 1,662
Sorry about the incorrect info you've received.
I'll make sure feedback is passed on.
mgfvvc
 I am shifting my email account to gmail, which is far more generous and efficient.
gmail can be good, until you have problems, but they really don't do customer support.
