Ticket 43313683 - Re LTB - Slow responses by support
- Feedback
- Plusnet Feedback
- Re: Ticket 43313683 - Re LTB - Slow responses by s...
Re: Ticket 43313683 - Re LTB - Slow responses by support
15-07-2011 6:16 PM
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
IP Profile for your line is - 6000 Kbps
Hi Adam
No change here. I'm afraid the fourth attempt to correct this problem hasn't worked.
15-07-2011 10:20 PM
All attempts by plusnet to correct these problems have failed miserably over the last several days.
I am sure plusnet will now have little choice but to admit they currently have a problem they are unable to fix.
Lets hope they find a solution to this problem soon. The longer it takes the more of us will develop the problem.
17-07-2011 12:18 AM
Quote from: _Adam_Walker_ cornwallsurfer,.
We do deal with consistency failures and fix them regularly
Hi Adam
It would be interesting to know when plusnet were last able to successfully fix a consistency failure!
17-07-2011 4:08 PM
BT Speedtest taken 4pm today. As you can see i'm still stuck on 6000Kbps at BT end :
Download speed achieved during the test was - 5365 Kbps
Additional Information:
Your DSL Connection Rate :10508 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
Perhaps you can let me know ASAP what the next step is.
Thank you
17-07-2011 8:23 PM
17-07-2011 8:26 PM
9 Mb
17-07-2011 8:29 PM
Uptime: 3 days, 6:26:18
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 10,511
Data Transferred (Sent/Received) [MB/GB] 0.00 / 3.00
Output Power (Up/Down) [dBm]: 12.0 / 21.0
Line Attenuation (Up/Down) [dB]: 21.0 / 37.5
SN Margin (Up/Down) [dB]: 20.0 / 5.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 4 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 39 / 0
FEC Errors (Up/Down): 4,440 / 0
CRC Errors (Up/Down): 4,440 / 19,698
HEC Errors (Up/Down): 54,446 / 17,267
17-07-2011 8:46 PM
I have no idea how (or if!) Plusnet can sort this...
17-07-2011 8:59 PM
Thanks for your post. That is just my luck! I did switch away from adsl max in June 2010 and have never had speeds above 6Kbps on the BT Speedtester.
I am glad you spotted the discrepency. This ticket was opened on 06 June 2011 and you are the first to identify a potential cause of this problem.
Hopefully Adam can look at this in the morning. There must be a way they can fix it!
I just assumed everthing was correct on ADSL2+ because router stats show :DSL Type: G.992.5 annex A
17-07-2011 11:06 PM
If it is a different model I suppose it's possible it doesn't interface too well with BT's systems.
18-07-2011 12:02 AM
Thanks for your post. I hope Adam looks at this side of things in the morning too.
All I know is that someone somewhere must be able to press the right buttons to sort this problem out. Up until now nobody has been able to get me above 6Kbps on a stable line that should be giving me a 9Kbps service.
So I am only acheiving 66% of the speed I should be getting in accordance to my sync rate.
18-07-2011 12:42 AM
18-07-2011 10:13 AM
Just to state, we have been making the requests to fix the inconsistency issue in the correct way and in the only way available for us to do so.
We have become aware now of a problem outside of our control which has now been fixed, with that in mind I'm making the request again now.
Let me know how things are after a couple of hours.
Adam
18-07-2011 10:16 AM
Fingers crossed again!
Will do a BT Speedtest after work. Will let you know how it goes
18-07-2011 1:03 PM
- Feedback
- Plusnet Feedback
