Thanks very much plusnet / openreach
- Feedback
- Plusnet Feedback
- Thanks very much plusnet / openreach
15-03-2013 9:04 PM
Had my fiber installed yesterday the engineer from openreach couldn't of been more helpful clean and tidy job, explained very well what he was doing and very polite,I have been with plusnet for a long time and recommend them to many people and businesses in IT at the time (I could of made a small fortune in referrals but i just took a couple) I have disabilities now so good to have someone helpful anyway would you have a look at my profile only showing 7 mb Thanks very much very happy customer
5 REPLIES 5
Re: Thanks very much plusnet / openreach
15-03-2013 9:14 PM
Hi Iain03,
Great to hear that everything went so well for you.
I'm in the office tomorrow morning so I will check that profile for you then (if it hasn't already sorted itself)
15-03-2013 9:40 PM
Hi Scott
Thank's for the quick reply at this time of day
16-03-2013 8:31 AM
The profile has now been increased for you.
Hopefully you are in bed at this time on Saturday and having a lie in so those speeds should be up to what they should be by the time you get this!
16-03-2013 10:57 AM
Hi Scott
You were right enough manage to get a long lie this morning
Thanks very much for sorting out my profile will check the speed later in the day do i need to disconnect and reconnect ?
Iain
Iain
16-03-2013 11:12 AM
Morning,
Glad to see that you've got a lie in.
The system will have automatically reconnected you when it applies to speed change so you won't need to do this yourself
Regards,
Matt
Regards,
Matt
