Thanks for wasting my time
maranello
I have just spent over an hour reviewing, transferring and deleting emails, only to find that most have reappeared in my Inbox. I was using the email client on my Android tablet because webmail is so slow, even then refreshing the Inbox and loading messages 50 at a time takes an age to load. The app is set up using IMAP.
By contrast, using the same app on the same device I was able to tidy up my gmail account in less than 5 minutes without problem.
When, if ever, are Plusnet going to fix the continuing issues with email and Webmail?
My other car isn't a Ferrari
9 REPLIES 9
rongtw
Fixes: 12
Re: Thanks for wasting my time
I honestly believe plusnet are incapable of fixing the webmail   Lips_are_sealed
Strat
Fixes: 565
@maranello you might want to take a look at this thread.
maranello
@Strat
Thanks for the link, and following through the crosslinks it was apparently affecting a number of users including you. I even responded to one of the threads but never got a response.
Was the issue ever resolved or is this another 'feature' of Plusnet email provision that users have to live with?
Strat
Fixes: 565
@maranello I just tried deleting an email on my mobile to see if it returned but the connection to the mail servers is very slow so not reliable enough for a meaningful test.
maranello
I have tried some testing myself and appreciate the difficulty. Tried different email clients under different platforms, different times of day both on a home connection and via my employers' network. Problems seem so variable and difficult to isolate a definitive cause. I appreciate why in this situation Plusnet cannot help individual users, but I would expect more pro activity in looking at mailer server performance to either eliminate this as a cause or monitor for performance shortfalls.
jelv
Fixes: 10
Have you tried doing a compact of the mailbox?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
maranello
@jelv
Not tried that, but thanks for the suggestion. Will this only be effective using Webmail or can it be done via a client?
Webmail still loading !!
jelv
Fixes: 10
Try both!
I found it helped for a similar issue when using Thunderbird.
maranello
Compacting the mailbox in Webmail appears to have done the trick. No further instances have been noticed since.
Thanks @jelv
