Thanks PlusNet
Akira
Thanks PlusNet
Just wanted to say thanks to the Plusnet staff. I had some problems to begin with but it's been smooth sailing since then. The support team were quick to respond and gave helpful advice. So, yeah guys...thanks!  Wink
1 REPLY
Re: Thanks PlusNet
Thanks for the kind post, glad to hear that you're happy with the way things got sorted for you Smiley
