Tech support reported fault on my line - but heard nothing since?
tooslow
Last week, Chris in support said that there was something odd on my line showing up at his end and that it would be fixed before my due activation date tomorrow 9th.
I have heard nothing. Is my line ready to go active by 9th December?
1 REPLY 1
Chris
Legend
Fixes: 169
Re: Tech support reported fault on my line - but heard nothing since?
The issue on the phone line as been reported as resolved now. I can't see any issues with your broadband order, so you should be good to go tomorrow.
