TG582 makes it look like the Pro add-on doesn't work
- Feedback
- Plusnet Feedback
- Re: TG582 makes it look like the Pro add-on doesn'...
- « Previous
- 1
- 2
- Next »
Re: TG582 makes it look like the Pro add-on doesn't work
17-03-2013 9:29 PM
Which firmware are you currently running? Is your model one with a USB port?
17-03-2013 10:07 PM
Quote from: Anotherone Which firmware are you currently running? Is your model one with a USB port?
10.2.2.9
No USB port
- « Previous
- 1
- 2
- Next »
- Feedback
- Plusnet Feedback
