Suggestion: £60 call out insurance
- Feedback
- Plusnet Feedback
- Re: Suggestion: £60 call out insurance
25-01-2012 9:51 AM
Would sufficient non-technical users who worry about this sign up to make in a viable scheme?
25-01-2012 9:56 AM
Without meaning any offence to anyone I think a lot of customers wouldn't go for it if we offered that as an option as I think it could be difficult to understand why they would benefit from paying the extra 25 per month.
We don't actually want anyone to have to pay the £60 charge and will help where we can to rule out the chances of that being levied, I can appreciate that some people to view the potential charge negatively or perhaps as a threat though.
25-01-2012 10:32 AM
Ultimately, the onus is on us to ensure that our processes, diagnostics and communication levels are sufficiently robust to ensure customer own domain checks are carried out fully and thoroughly.
As Adam has said, we don't want any customer incurring this charge and if investment is needed that's where it should focus.
M
26-01-2012 6:38 PM
I have never been charged in 6 BT visits, maybe the screening process works?
26-01-2012 8:16 PM
I say proves conclusively, as we have a mechanism to dispute such charges and use it effectively.
M
26-01-2012 9:18 PM
I class that as self inflicted, just like parking on a double yellow line
27-01-2012 10:29 AM
We actually considered this when we revamped the engineer charging process recently, but dismissed it for various reasons,
1) It would actually be counter-productive in a lot of ways
- having 'insurance' would mean customers would be less inclined to do checks required to raise a fault, meaning more engineers sent out unnecessarily
- much higher costs to us (engineer visits cost us much more than the £60)
- fault resolution times would be increased meaning more dissatisfied customers.
2) There are a number of rules around insurance/credit schemes which make the process much more complicated
3) Most customers will never need a BT engineer - I've had broadband for over 10 years and I've never had an engineer visit - I wouldn't want to pay either a nominal fee each month unnecessarily and I'm sure many other customers would feel the same
27-01-2012 12:14 PM
So while I would totally agree that many will feel it is a lot of money, it is not out of line with that charged by other similar serving organisations.
Again, other areas of the country may be cheaper in this respect
27-01-2012 1:22 PM
It's rather different a washing machine repair when people will accept that if it is out of warranty and it's broken they will have to pay.
27-01-2012 3:01 PM
The only routine exception to this is where the customer says they can't/won't try another phone/router and it turns out to be the handset/router that is the problem.
The best case scenario for us is that we don't get charged for any engineers, which in turn means no customers get charged.
We've created a process where we look at every charge and only pass this on where the engineer notes are sufficient for us to be confident, and as Mark said, we use the dispute mechanism effectively to increase quality
27-01-2012 3:06 PM
Quote The issue here is that many people are very upset at being asked to confirm that they will accept the £60 charge should the fault prove to be the user's side of the test socke
I'd agree that we can and indeed are beginning to use the ability to dispute as leverage for better quality service. I think the one thing we do need to keep on top of is how we sell the message as I can easily imagine that a poorly worded or phrased explanation of the potential charges could put customers off wanting to raise a fault.
27-01-2012 3:17 PM
On the forums people complain about being 'threatened' with a call-out charge for an engineer when they're convinced that the fault is external or complain that they have to 'go through the rigmarole of checking this and that, plugging into the test socket etc....
If the wording eas along the lines of 'We advise customers, on each occasion a fault is reported, to follow the simple step by step instructions given. This should ensure that internal wiring and equipment is eliminated as a source of faults otherwise our suppliers charge us for a call-out where your wiring or equipment is found to be at fault and we must regrettably pass on this cost.'
Sorry, I have not read through the current wording so I may be a bit off the mark here but customers need to percieve the tests as simple and as a means of avoiding the possible charges rather than a threat of being charged.
31-01-2012 2:52 PM
mentioned in any of the written terms and conditions and I am convinced that it is wrong. I'm sure they do it to try to reduce their workload, especially for intermittent faults. The engineer that visited last said that he had found a problem and implied that I
would have been charged if he had not found and fixed it. This is all despite the fact that the fault was obvious when I phoned
to report it. Hope this makes sense.
FWIW I've had broadband for nearly 10 years and I've needed several engineer visits (some were arranged for voice faults
though).
01-02-2012 10:21 AM
01-02-2012 10:32 AM
I understand where you are coming from.
BTs responsibility to us (and therefore you) to to supply service to your NTE (master socket). Is the problem is being caused by something past this point and it hasn't been checked by you (after we have asked you to), then we are charged £144+VAT. The engineer charge that we apply of £60 inc VAT is considerably less than this. Also, if you have done the checks that we ask you to, then this will not be charged.
I understand that it can at times feel like we are threatening charges, however, all we're really doing is to ensure that you do not get charged and that the fault can be rectified without an engineer needing to be sent and thus delaying the resolution of the fault.
I personally don't buy the idea of the "call out insurance". I would not want our userbase (or everyone that signs up for it) to suffer because of a potential charge which would be applied because someone hasn't managed to go through the checks which our staff carefully detail on all faults.
Noone likes having to pay additional fees, but I think in this case it is as fair as it can be.
