Speed dropped from 20Mb to 200kb
- Feedback
- Plusnet Feedback
- Re: Speed dropped from 20Mb to 200kb
16-01-2014 3:53 PM
I'm on the exchange in Bacup, OL13. I've reset my router (a Cisco 1801) etc, and it still tells me I am connecting at around 20Mb/s down, but I can't get over 200kb/s on any protocol. I tried to run a speedtest and gave up because it was taking too long.
Not sure when it started but it was OK early this morning and wasn't when I got home at 3pm.
At the moment the internet is barely usable; I'm not looking forward to my wife getting home later and not being able to watch BBC iplayer!
16-01-2014 4:47 PM
I've checked your profiles and connection history, can't see any drops or changes to the profile (it updated again to 18400 yesterday, which is where it's been for at least a couple of months). It's looking like a fault to be honest, though I'm afraid we'd need BT speed test results (http://speedtest.btwholesale.com) and a fault raising at http://faults.plus.net in order to get this sorted out for you. If you could do those our team will get it investigated and escalated for you.
16-01-2014 6:56 PM
Thanks for the reply. I'll do the necessary tomorrow morning if it's still slow - no time right now.
Taking the misses out for a meal to avoid the lack of internet TV, lol.
17-01-2014 10:12 AM
I bought a 582n from Plusnet just for testing due to the repeated exchange issues and being asked to try another router.
It has not been used until today, but I can't even get it to connect reliably. The broadband light will eventually go steady, and I think, "ah-ha, it's finally got it" then after 20 seconds it will start flashing again. Wahh! (Yes, I followed the instructions which tell me to wait until the bb light is steady, lol, then I tried manually entering my settings with the same (lack of) result).
My connection is even slower this morning. The BT speed test comes in at between 2Mbps and 3.5Mbps but even that's rubbish; I see nothing like that in real-world use on my PC.
When it works it's absolutely great, but when it doesn't...
Oh well, here we go again. Ticket raised. I hate BT.
Oh, and another thing... I tried running the TAP3 test from the BT site, but could not get a network connection (to BT) after changing my username. I guess it's because I have an IP block and wasn't connecting from the IP address assigned to the router. That was another reason I was trying to get the Plusnet router connected.
17-01-2014 10:26 AM
That's sounding like a dropping connection fault rather than a speed fault. I suspect that's why you're not getting the connection - the IP block only comes into effect when connecting to us as it's after the connection is established that you're issued the IP (afaik) - only reason that'd prevent you connecting is if you've set the IP as static in the router, in which case it won't accept any others.
I'd recommend mentioning that on the ticket, here's your connection log from when you changed the router over:
<img src="http://community.plus.net/visualradius/generated/image13899543033798.png"/>
Looks like the router you're using is very good on lines with a lot of noise on them.
17-01-2014 5:26 PM
Now we can watch Sherlock! No we couldn't, although it tried for a while. thought it just needed time to settle in again.
If 'twas Plusnet that sorted it, thanks, if not, thanks anyway.
Since this is my hundredth post here, I'll finish on a positive:
The only connection issues I have ever had have been BT/Exchange related. PN, despite me really hating having to do the usual tests when BT mess things up, has always been great.
17-01-2014 11:41 PM
BT Speedtest now at only 1.5Mb (and nowhere near that real-world), half of what it was yesterday
Thinkbroadband shows a slightly truer picture with 0.6Mbps down; less than my upload speed which seems unaffected
http://www.thinkbroadband.com/speedtest/results.html?id=139000260368446299212
This feels like I'm back on dial-up
18-01-2014 7:36 AM
18-01-2014 2:04 PM
I've just reconfigured my router to allow the BT TAP 3 test - 0.3Mbps download
Still can't get the technicolour to connect; broadband light goes steady for 20 seconds, then starts flashing away again.
All this just to catch up with the last episode of Sherlock!
10:1 it's BT again, or some moron with a floor saw and a backhoe.
18-01-2014 7:02 PM
I knew I was pushing my luck calling support. They said something about increasing my S/N ratio margin.
Now I'm syncing a good 3Mbps lower than ever before, and still not much change in my actual download rate.
My connection (apart from exchange issues) has been great without being fiddled with for years. Please can it be put back how it was? Or is it something that will gradually adjust itself back to where it was? It's obviously not the root cause of the issue.
(not that it makes a difference right now though... it's not exactly the limiting factor!)
Oh, and I was impressed by being answered immediately that the message, "the waiting time is over an hour," had finished. Quite caught me off guard that did!
21-01-2014 2:33 PM
22-01-2014 11:10 PM
