Shambles of a transfer from TalkTalk to PlusNet
friendinneed
Installation date quoted as 28/11/2014
On the morning of 27th, phone line and broadband still connected to TalkTalk and working.
Shortly after midday on 27th, phone line dead, and obviously no broadband. Ring PlusNet to see if they have done anything early, and told "Yes, the move has been completed"
Rang again around 5.30ish, and after queuing on phone for 20 minutes got through to support around 6pm, was told that order had not been completed and it was a provisioning problem. 20mins queuing for provisioning, was told that the order had been completed and it was a support problem.Asked for problem to be raised with support and was told it would take up to 24 hours to raise it.
Rang in this morning just after 9am and asked if the problem had been raised. Was told that the problem team didn't open until 9.00, and it had just been raised, and would probably be looked at in the next 12 hours
Rang at 2pm to see what progress, and told that there is a line fault and estimated fix 2nd December. Obviously a line fault as there was no dial tone. Perhaps the Openreach engineer hadn't bothered to correctly move a working line from one switch to another in the exchange?
So, leaving aside the incorrect date for the transfer, it took over 12 hours to raise a fault, Openreach / PlusNet lied about the transfer being complete, and when I asked to speak to a supervisor was told that they might call me in a couple of hours.
Looking at the call statistics shows no information at all, and on ringing up you are told the waiting time is around 30 minutes
Was also told that there was no number to call to escalate the complaint.
9 REPLIES 9
adamwalker
Fixes: 223
Re: Shambles of a transfer from TalkTalk to PlusNet
I'm really sorry about the issues you've mentioned here.
The order did actually complete which just means we're now needing to deal with the issue as a phone fault.
Apologies again for the poor start and we're hoping to see this resolved by the end of the day on the 2nd for you.
 Adam Walker
friendinneed
This is problem #95373059 Is there any further information on this?
plusnettony
Fixes: 48
It seems that there has been some action today. I've updated the ticket and returned the fault back to BT for you.
Tony
 Tony T
friendinneed
Does this count as progress?
jim:quote
adamwalker
Fixes: 223
Yes, I'm glad to see engineers are working on this again as of approximately 9.30am today.
 Adam Walker
friendinneed
Well, there is now a dial tone, but dialling any number gives "That is not a valid number"
Chris
Legend
Fixes: 169
Shortly after you made this post we received a 'clear' notification that a problem had been resolved. If you're still having issues can you let us know so we can reject the fault back.
friendinneed
Yes, can now make calls in and out. Will be setting up BB tomorrow morning. Thanks
adamwalker
Fixes: 223
Hi friendinneed,
Thanks a lot for letting us know.
I'm glad to see that your broadband is up and running too from our point of view
In case you were wondering that was me trying to call just now just to make sure everything is up and running as expected.
 Adam Walker
