Really slllllooowww after 4pm...anyone else
simplesimey
Have just put a ticket in as my plusnet value broadband speed is about 6MB (really good) up to 3:59pm and at 4:01pm goes down  to about 100 - 200 KB .... this makes loading a plus.net support page for example takeing more than a minute....  My flatmate has reverted back to using a dongle on his Mac i.e unusable! Just checking if this is others experience so I know if its not just me? Please bear in mind the support team may have an answer if just me....  Cheers
6 REPLIES 6
paulpicks21
Re: Really slllllooowww after 4pm...anyone else
Mine seems fine , stays the same speed at all times.
Perhaps some trouble with your local exchange?
Paul.
Fixes: 1,495
find your exchange here and see if it has an issue.
simplesimey
I thanks for replies and feel a bit more confident can be resolved. I noticed it was slow on monday pm (could have been slow before this) and have been working at home this week and doing regular speed tests and at 4:00pm speed just falls of cliff....checked exchange and no reported probs ....
paulpicks21
Are you sure your wireless router is secured?
Perhaps at 4pm every kid on your road gets home from school and piggybacks onto your router to play xbox or playstation  Grin
simplesimey
don't think kids are that reliable to get online at 3:59:59 ... Smiley
adamwalker
Fixes: 223
simplesimey,
I've checked your exchange status and this is flagged as green at the moment so contention may not be the issue. Theres nothing in the way of traffic management that should impact you here either. As things stand I can see that you have performed a BT speed test for us, could I please ask you to check this at 4pm today and perform another test for us? I only ask as the first tests only highlights a slight drop in throughput speeds.
 Adam Walker
