Re: (intermittant issue) how to communicate with these guys
- Feedback
- Plusnet Feedback
- Re: (intermittant issue) how to communicate with t...
on 02-02-2017 12:11 PM - last edited on 02-02-2017 1:17 PM by Strat
I can't find out how to communicate with these guys.
Where can I send the following email?
Dear sirs
I have spent 40 minutes waiting to get through to you in the last 24 hours - and I also have a job to do. High call demand as your recorded message states, is the result of increasing problems and/or insufficient staff.
We recently changed to Plusnet at home and have had inconsistent access which wasn’t the case previously.
I have logged failures recently as follows:
21 Jan 22:50 hrs
23 Jan 20:40 hrs
28 Jan 09:45
16:40
30 Jan 21:00
31 Jan 18:32
1 Feb 18:05
22:45
23:17
I cannot say how long each of these interruptions lasted though for some I rebooted the router and was reconnected.
These are just failures at times my wife and I have been at home and using the internet - there may well have been other times when we were away.
This service level is unacceptable as it interrupts our listening to internet radio programmes and disrupts downloads of business files that are regularly needed as I run a charity in Sierra Leone where the sender may only have access to internet at night.
Also am a director of a professional accounting body in Australia and require video and voice communication with colleagues in Melbourne.
I have none of these consistent problems with the connection at my office in Bowdon.
You may gather that I am less than pleased with your present service level and should be glad to know:
Most urgently what can be done about the lack of reliable internet access, and
What are you doing about improving your communication facilities to something better than those reputedly of TalkTalk and others?
Re: (intermittant issue) Fibre & BT Tests show errors
02-02-2017 1:16 PM - edited 02-02-2017 1:17 PM
Moderator Note by Dick (Strat)
Post split to its own topic for clarity and title edited.
02-02-2017 1:42 PM
We can see your line is disconnecting frequently as per the graph below:
| Test Outcome | Pass | ||||
| Test Outcome Code | GTC_FTTC_SERVICE_0001 | ||||
| Description | GEA service test completed and no fault found but unable to check for customer equipment connected to modem. | ||||
| Main Fault Location | OK | ||||
| Sync Status | In Sync | ||||
| Downstream Speed | 43.6 Mbps | ||||
| Upstream Speed | 17.6 Mbps | ||||
| Appointment Required | N | ||||
| Fault Report Advised | N | ||||
| NTE Power Status | PowerOn | ||||
| Voice Line Test Result | Pass | ||||
| Bridge Tap | Detected | ||||
| Radio Frequency Ingress | Not Detected | ||||
| Repetitive Electrical Impulse Noise | Not Detected | ||||
| Cross Talk | Not Detected | ||||
| Estimated Line Length In Metres | 453.7 | ||||
| Upstream Rate Assessment | Low | ||||
| Downstream Rate Assessment | Reasonable | ||||
| Interference Pattern | Regular Interference Observed on Week Days | ||||
| Service Impact | Retrains Observed | ||||
| Interference Duration Longest Occurrence | From 08:30 to 09:00 | ||||
| Interference Location | Unknown | ||||
| Interference Observed In Days | 6 | ||||
| Home Wiring Problem | Not Detected | ||||
| Downstream Policing Discard Rate | 0.0 | ||||
| Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
| Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Retransmission Low | ||||
| Time Stamp | 2017-01-20T13:45:00 | ||||
I'd advise getting this reported to us as a fault at https://faults.plus.net
- Feedback
- Plusnet Feedback
