Quality of service
ukolsch
Quality of service
Connection keeps dropping, and I have to reboot the modem every time to get it back. Plus.net customer service tells me this has to happen more than twice daily to be considered a fault. See details of conversation with customer service here -
[Moderator's note by Jim (Oldjim)  Link removed - please see following post mod:end
5 REPLIES 5
Oldjim
Resting Legend
Fixes: 63
Re: Quality of service
It is against the Forum Rules http://community.plus.net/forum/index.php/topic,218.0.html#post_contact to post the names of CSA Agents
As such I have removed your link and would ask that you remove the names before reposting it
w23
Fixes: 4
How often is it dropping since the engineer's visit?
Did the engineer replace the modem?
Call me 'w23'
Pettitto
Fixes: 5
I'm sorry to hear of the issues you're having with your connection, ukolsch.
I've had a look over your connection and can only really echo what the Faults Team have mentioned - your line is stable:
<img src="http://community.plus.net/visualradius/generated/image139349789037.png"/>
When do you generally see the drops in connection? I appreciate that not all (but most are) drops aren't registered on the above graph so any extra information you can provide would be most helpful.
picbits
*Edit - Chris beat me to it.
jelv
Fixes: 10
How do you connect to the router, wired or wireless?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
