Provide a server on Speedtest.net/Ookla for more accurate results
SOLVED
tex
Solved!
Message contains a hyperlink
Since it's a very popular speed testing service I would recommend PlusNet add a dedicated host to their pool which we would automatically connect to and find our true speeds since peering would be avoided/minimised.
Tags (2)
5 REPLIES 5
RichardB
Seasoned Champion
Re: Provide a server on Speedtest.net/Ookla for more accurate results
PN used to host an Ookla speedtest at www.mybroadbandspeed.co.uk.
The server could not cope with the mass take up of FTTC services & gave erratic results.
Looking at www.mybroadbandspeed.co.uk this morning, it looks like PN are only hosting the  Ookla front end and offloading the speedtest traffic to other servers.
Moderator's note by Dick (Strat): Links fixed (typo).
tex
Quite surprising an ISP couldn't handle the traffic. The www.mybroadbandspeed.co.uk website appears down for me too, and PlusNet's documentation says to tests speeds at www.speedtest.btwholesale.com but that doesn't work since Flash is disabled in my browser, just like it is for most Google Chrome users now.
Moderator's note by Dick (Strat): Link fixed.
They ask you to use the BT speedtester as the results are available in the BT wholesale back end.
It makes escalating speed faults much easier.
Flash can be enabled per site on Chrome, it gives you a pop up. Or an alternative browser could be used.
As you observe many browsers are defective.
BT Wholesale speed tests are an essential part of the diagnostic process - you need to find a functioning web browser. Theses new hip browsers are riddled with deficiencies.
adamwalker
Solution
Thanks for the suggestion on this Tex. - Adam
 Adam Walker
