Plusnet: the slowest broadband I ever had
sreejithp
My broadband connection is dropped to a painful 90kbps from 2MB. I moved to Plusnet 3 months ago and was getting around 2MB speed till a week ago.All of a sudden the speed dropped. The customer service difficult to reach and often of no help as most of the time the answer is contact fault dept and so on. They have turned on interleaving and for a short period the speed improved to 0.5MB and dropped again below 100Kb. There is nothing changed at my end the router is connected to the test socket for the pas one week. The strange thing I noticed now is if I got to the BT site now to check the max speed supported on my line is showing as 135 kbps.
Any help to resolve this is highly appreciated
Sreejith
17 REPLIES 17
sreejithp
Re: Plusnet: the slowest broadband I ever had
speed test details from BT
Download speedachieved during the test was - 107 Kbps
For your connection, the acceptable range of speeds is 50-250 Kbps.
Additional Information:
Your DSL Connection Rate :160 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 135 Kbps
scootie
can you grab your line stats from your router please. If you need any help in finding them then follow this guide http://www.kitz.co.uk/adsl/frogstats.php
orbrey
Hi sreejith,
Up until a couple of weeks ago (I imagine that's when the slow speeds started) you had a fairly intermittent connection, which will be what's dropped the speed. In turn it's the slower speed that's meant your line is now stable again.
The best thing to do would be to raise us a fault at http://faults.plus.net (as an intermittent connection rather than slow speed) and we'll get this investigated for you.
Sorry to hear of the troubles here.
sreejithp
Matt,
  A fault is raised on 23rd March (ID : 32644305 ). Do you want me to raise another one ?
sreejithp
Quote from: Asbo
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 3510 4116 0 2191 6090 00:10:00
LAN 10M/100M 579 0 0 234 0 00:11:20
WLAN 11M/54M 4587 3989 0 5741 2157 00:11:10
ADSL Link Downstream Upstream
Connection Speed 2912 kbps 448 kbps
Line Attenuation 47 db 14 db
Noise Margin 10 db 24 db
Oldjim
Resting Legend
Fixes: 63
Looking at those stats and your IP profile something has gone badly wrong with your connection.
As a first step can you post the results when connected to the test socket
sreejithp
Quote from: Oldjim
WAN PPPoA 1043 1298 0 517 2868 00:07:18
LAN 10M/100M 1639 0 0 85 0 01:44:04
WLAN 11M/54M 33269 28802 0 4384 1201 01:43:54
Connection Speed 3584 kbps 448 kbps
Line Attenuation 48 db 14 db
Noise Margin 12 db 24 db
Oldjim
Resting Legend
Fixes: 63
Well that tells us one thing - your internal wiring isn't helping
To explain - your speed increased from 2912 to 3584 with a noise margin increase from 10dB to 12dB. The reason for that is that your default noise margin is now 12dB and your previous resync was probably during the day when there is less interference - with the same noise margin you could probably have achieved a speed of around 4000 kbps
Can you repeat the exercise with the router plugged into the master socket (not the test socket) with nothing connected to the extension sockets
The other part is why your profile dropped to 135kbps
Did anyone connect an unfiltered device and then removed it and have you got a Sky box
sreejithp
Thanks Oldjim
WAN PPPoA 4433 4905 0 740 2206 00:26:17
LAN 10M/100M 1779 0 0 78 0 02:03:03
WLAN 11M/54M 36968 32386 0 4023 1150 02:02:53
Connection Speed 2880 kbps 448 kbps
There is nothing plugged without filter. Infact nothing changed recently and I don't have sky
Oldjim
Resting Legend
Fixes: 63
You have an internal wiring problem which will need sorting out but that might be as simple as disconnecting the ring wire from the removable faceplate.
Can you take a picture of the back of the removable faceplate and post it using the Additional Options button.
However I note that in your first post you say you were connected to the test socket for the past week so if you can leave it like that we can try and find out why your speed dropped so badly.
We need to ask Plusnet when the low sync event occurred - I will flag it up in the Moderators Area and hopefully a member of staff will pick it up.
Can you leave it connected to the test socket and see if the router log shows any more drops. It would be worth trying another filter.
sreejithp
Sorry oldjim
where is the additional option button ?
sreejithp
Oldjim
Resting Legend
Fixes: 63
That shows the two wires you need and the ring wire and the one which you should remove is the orange one which should be connected to the terminal numbered 3 (2 and 5 are the ones you need to keep that is the blue/white one and the white/blue one)
I might note in passing that the wiring is very neat - obviously a professional job.
This is worth a read http://www.kitz.co.uk/adsl/socket.htm
sreejithp
Jim, Thanks Very much for the help you provided. I will keep it connected to test socket and will remove the orange wire when I put back the plate
