Plusnet - the final stupidities
FIXED- Subscribe to RSS Feed
- Feedback
- Plusnet Feedback
- Plusnet - the final stupidities
30-09-2026 11:50 AM
Used to be a great company but no more: First I had to move my email provider to avoid the Greenby train wreck. Now I'm told that I can be "moved" to EE with a broadband connection and VoIP phone, but loose my static IP. Or I can remain with Plusnet and keep the static IP, but without phone. It says that I can terminate the contract at no cost because of the loss of static IP.
So I call the "Support" number and ask if I can just port the phone number to another provider and stay with Plusnet. Get told that Plusnet would immediately cancel the contract and charge me a termination fee for the privilege. Is that right? You are going to drop the phone line anyway, but won't let me port the number without throwing your toys out of the pram?
After a couple of calls to "Support" I realize that you can't get any sense out of them. And the story changes each time. So, I ask "Support" to raise a complaint ticket so that there is a written audit trail (they did away with "Chat" support a while ago, although one of the "Support" folks tried to tell me otherwise - until I told him go check). Eventually, after a lot of persistence on my part and a lot of wasted time, I get a ticket raised. And add the details of my complaint and the resolution I'm after, as follows:
either:
(a) Plusnet allow me to port the landline number but keep existing broadband and static IP up to end of contract. I will decide at the end of contract whether to renew with Plusnet or move to another provider.
or:
(b) I port both landline number and broadband to another provider. Plusnet allow this and do nothing that would inhibit it. Plusnet also refund me the entire balance of the account without any termination fee.
In view of the short timescale (imposed by Plusnet) if I do not receive a satisfactory resolution before Monday 5th October I will initiate option (b). In that case I require that Plusnet do nothing to impede this and to refund me the entire balance of the account without any termination fee.
What does Plusnet do? "We are closing this ticket as we are no longer able to support queries raised online. Please call us on 0330 123 9123 and we will be able to support you further." Humm - that'll be the support number that you can't get any sense from and it will be able to "support" me further than the closing-ticket-no-support-at-all "support"? I don't think so. And YOU, Plusnet raised the ticket - why do that if you can't support it? Doh!
So next week I think sees me porting the number and the broadband and then probably a complaint to Ofcom when (as seems likely) Plusnet manage to sabotage this in some way and/or refuse to refund my money.
Fixed! Go to the fix.
Re: Plusnet - the final stupidities
30-09-2026 12:04 PM
@LSAS wrote:
... It says that I can terminate the contract at no cost because of the loss of static IP.
If you have this in writing then I fail to understand your problem. If your account is in credit then providing you leave your current payment method in place this will be refunded when the account is finally closed, which will be a few weeks after leaving.
30-09-2026 12:05 PM - edited 30-09-2026 12:06 PM
You should be able to stay with PN and move your landline to a VOIP provider.
What you need to do is change your account to either SOGEA (FTTC without the phone service or Full Fibre if it's available and you want it). This will involve a new contract. Once it it confirmed you have moved then you port the number.
You CANNOT port the number prior to this move.
You can look at the following to see what's available to you or phone the PlusNet Customer Options Team on 0800 013 2632
Your Static IP is tied to your account, not your contract or the product your on.
30-09-2026 12:11 PM
To explain this
Currently , your broadband and phone contract is based on the phone number as the 'primary Openreach asset'. If the phone number is ported it ceases the primary asset and thus closes the account.
You can change your product to a broadband only (SoGEA or FTTP) product which will disassociate the broadband from the phone and just cease the phone. You can then port the phone number to voip within 30 days. Note that the change would involve a new contract but would retain your static IP
30-09-2026 12:14 PM
Note EE Digital Voice and VoIP are not the same.
EE Digital Voice is delivered via the EE Hub only i.e. you will not get SIP Credentials or SIP Server details.
VoIP has greater complexity to set up but offers complete flexibility of ISP, location & type of device used.
30-09-2026 12:17 PM - edited 30-09-2026 12:19 PM
The answers 2 and 3 and 4 above are correct. Read them carefully, because they’re coming from slightly different points. Decide whether you’re pursuing your proposed options a or b.
[edited to include answer 4 (which appeared while I was typing) and the helpful answer 5.]
30-09-2026 12:17 PM
"This will involve a new contract. Once it it confirmed you have moved then you port the number"
That's basically a ransom demand - you can't port your number unless you sign up to a new contract. And I probably don't want a new contract with such a stupid company anyway. In any case, I'd prefer to let the existing deal run and chose at the end.
And I don't want to (yet again) call "PlusNet Customer Options Team on 0800 013 2632" because you cannot rely on what they say (that's when you are not on hold, listening to loud and unpleasant "music").
BTW: "SOGEA" is what I already had but with landline cut off (and I know that the broadband already works without a landline following a landline fault a couple of months ago)
30-09-2026 12:23 PM - edited 30-09-2026 12:28 PM
Can you confirm whether you broadband is ADSL or FTTC ? - as the outcomes are different.
Assuming that your broadband is FTTC then -
@LSAS wrote:
... I call the "Support" number and ask if I can just port the phone number to another provider and stay with Plusnet. Get told that Plusnet would immediately cancel the contract and charge me a termination fee for the privilege. Is that right?
Yes that is technically correct (by omission). If YOU unilaterally port your phone number away to another provider while your broadband is FTTC then doing that will close your Plusnet account.
@LSAS wrote:
... Or I can remain with Plusnet and keep the static IP, but without phone
Yes, you can do that, BUT when your account account is confirmed to have had the phone service removed, the phone number is held 'in quarantine' for 30 days, and within that time period you can port your phone number to a third party VoIP provider.
If you want to stay with Plusnet and keep your static IP and your phone number (ported to VoIP) -
- In your Member Centre, 'upgrade' your broadband from FTTC to SoGEA (FTTC without phone) or FTTP.
- Wait until you get email confirmation from Plusnet that the 'upgrade' has completed.
- Then 'port' your phone number to a third party VoIP provider.
Or take everything and move to an ISP that values their customers, and isn't in a self inflicted death spiral !.
EDIT: my typing was too slow, and most of these points already got answered !.
30-09-2026 12:23 PM
If you already have SOGEA, why did you not port your number at that point? If it was more than 30 days ago, it is lost anyway.
30-09-2026 1:21 PM
Are you sure you have SoGEA?
Just because your broadband kept working when the phone was not, does not mean you are on SoGEA. Your services infrastructure has three network components...
- Copper d-side connection from the cabinet to the house - carries voice and VDSL (broadband signal)
- Copper e-side connection between the cabinet and the exchange
- Fibre to the cabinet connection from the exchange
A failure of (2) will 'cut off' the telephone with zero impact on FTTC broadband.
A part-failure of (1) [single leg disconnect] will 'cut off' the telephone whilst potentially leaving FTTC broadband operating in a degraded manner, which can pass unnoticed.
If you truly have SoGEA - then this whole discussion is utterly nugatory. However, given you have been in discussion with PN over porting the number away you MUST still be on FTTC.
30-09-2026 1:45 PM
30-09-2026 4:41 PM
@LSAS said:-
"...ask if I can just port the phone number to another provider and stay with PlusNet..."
"..."SOGEA" is what I already had but with landline cut off..."
I'm a bit confused. So do you currently have an active landline?
30-09-2026 5:09 PM
My point was that SoGEA is effectively just a brandname - taking what was a working connection to the customer and disconnecting the baseband component while leaving the broadband HF down the same wires from the cabinet. So what I currently have is FTTC which is a baseband POTS connection with superimposed broadband. (And the previous failure was #2 on your list)
If I were daft enough to take out a new contract with Plusnet they'd just have OpenRetch disconnect the POTS component from the exchange to the cabinet and rebrand the remains as SoGEA - good work for OpenRetch coz they can then sell off all that loverly copper 😉
So, Plusnet won't let you simply port the number, even though you are going to loose it anyway when they disconnect the baseband. Instead they insist you take out a new contract or they charge a termination fee - for terminating a contract that Plusnet have broken. And if you want to discuss this with them - as they say "Good Luck With That".
The only way to contact them is by phone - they've done away with Chat and though I managed to get them to raise a "support" ticket they immediately closed it again. And the phone "Support" is like a bad parody of what you would expect from an evil company pretending mere incompetence. Perhaps that's the game - drive away all but the ignorant customers, those who will put up with anything, reduce service, increase prices and enjoy the extra profit while it lasts.
Anyway, looks like my Get Out Of Jail card is probably the static IP - whether Plusnet will let the port go ahead without causing trouble remains to be seen...
30-09-2026 5:18 PM
"Or take everything and move to an ISP that values their customers, and isn't in a self inflicted death spiral !."
I've come to the view that this is what anyone in their right mind would do. I'll wait till next week to see if I can get any sense out of them, failing which I'm off.
PS: Broadband is "Unlimited Fibre" = 40/10 FTTC = VDSL-2 to house
30-09-2026 5:26 PM - edited 30-09-2026 5:27 PM
SoGEA is not a brand-name it is a technically differently configured product, most notably how it is "built" in the management systems. As has been explained FTTC is built over a telephone product, SoGEA is not.
If you "port away" the number on a FTTC service you'll "crash out" the whole configuration, including your Plusnet service account. Plusnet is not stopping you porting your number, but the process must be done in a graceful manner, the rub for you is that it needs a new fixed term contract.
Plusnet has given you a penalty free option: migrate to EE switching to SoGEA (or FTTP if available) and Digital voice for the same price tied only until the end of the existing contract. They have even gone so far as to add that if you have a fixed IP address, given that EE cannot offer a fixed IP address, you can terminate the contract without ETCs and do whatever you want.
If however YOU chose to keep your broadband service with Plusnet and port the telephone number to another VoIP provider you can do that too ... though that requires a new SoGEA or FTTP contract with Plusnet.
There are a good few choices available, but be careful a unilateral number port will cause mayhem. I am not sure what the process is for exiting without ETCs having a fixed IP address. In the case of a past special exceptions escape clause, one had to notify the business of the intent to use the special exit conditions before doing so. I will ask for you.
