Plusnet phone support
Steevo
What is happening? Phoone lines to call PN  are awful quality currently. Why is this? CS rep i spoke to confirmed there was a problem at PN end.
4 REPLIES 4
adamwalker
Fixes: 223
Re: Plusnet phone support
Hi Steevo.
We're not actually aware of any current problems with the phone system although you may notice we had some problems causing some calls to be dropped which was closed yesterday: http://usertools.plus.net/status/archive/1411635838.htm
What was the problem exactly? i.e was there noise on the line/was the call quiet etc.
I'll try and find a recording of your call to see if I can spot any issues.
 Adam Walker
Steevo
Thanks Adam, much appreciated.
Fixes: 254
Were these calls on Steevo's land line - the one which trashes the DSL session on inbound calls?
Could that be impacting call quality?
Steevo
You have a very good memory Townman!!
But no, for fear of creating more problems I'm steering away from using the landline as much as possible so made the call from the mobile.
Thank you for your input all the same, it's nice to have a friendly face!
