Plusnet as a "Homepage"
longlostpoet
i cant seem to find anything relating to a Plusnet "Homepage"
so i am stuck with the one from my last provider Sad
Fixes: 131
Re: Plusnet as a "Homepage"
Welcome to the forum longlostpoet.
You mean this https://portal.plus.net or this http://www.plus.net/  Undecided
Customer and Forum Moderator.
ChrisL
In any case, surely you can set any Homepage you like in your browser?  Look at 'Internet Options' on the 'Tools' drop-down menu (for instance)....
HTH
Chris
David_W
I *think* they may mean a proper portal with news feeds and stuff.
You could try setting it to iGoogle (what's with the i there?) which you can customise to your own desires, this link should work:
http://www.google.co.uk/ig?hl=en&source=iglk
Fixes: 68
tsk! Wink
longlostpoet, drop me a message if you still need a hand with this.
 Adam Walker
If you need a hand changing your home page (sorry if you don't it's not clear Smiley) we have a support page showing you how here:
http://www.plus.net/support/software/browsers/homepage.shtml
