Plusnet Complaints Code of Practice
- Feedback
- Plusnet Feedback
- Plusnet Complaints Code of Practice
Re: Plusnet Complaints Code of Practice
05-02-2014 11:30 AM
The TAP3 Test issue seems to be intermittent across the board and it's quite difficult to find a pattern to identify the issue. I'll keep you posted on any progress I get on this.
For any other posters facing similar issues, please feel free to PM me screenshots of TAP3 failures you're seeing too - thanks!
05-02-2014 12:32 PM
Quote from: Chris For any other posters facing similar issues, please feel free to PM me screenshots of TAP3 failures you're seeing too - thanks!
Include a view of your date and time in that screen shot!
Ex-Plusnet Jobsbody
06-02-2014 3:40 PM
06-02-2014 4:26 PM
Each time I have tried the test I have first used the 'Go' button and then, when that failed, tried the manual test3.speedtest.btwholesale.com link.
Whilst I am using my Billion 7800n rather than a standard issue router I cannot think why it would have any impact on the connectivity in this case?
06-02-2014 4:30 PM
Is your router definitely connecting ok to the test account? Some routers you need to also put in a password (anything like testing) otherwise it also does not work.
06-02-2014 7:01 PM
I am not aware of any settings specific to the router but have raised a query on the Billion forum.
11-02-2014 10:47 AM
Following advice from the Billion forum I connected directly from the PC to the ECI modem, excluding the Billion, and tried to access the test again. Still no luck.
@Chris
Are BTW able to explain what the problem might be?
11-02-2014 10:48 AM
I'm still looking for more and more examples if I can get them.
12-02-2014 12:27 PM
Are you able to replicate the problem with these temporarily disabled at all?
13-02-2014 10:18 PM
Another attempt bypassing the router, this time with anti-virus and firewall disabled - still no TAP3 connection.
14-02-2014 9:09 AM
Thanks very much for your help with this.
21-02-2014 10:18 AM
Any response from BT as yet or have they forgotten about it?
21-02-2014 10:44 AM
Would this be okay? If so, could you PM me with your availability and I'll pass it back over to them.
21-02-2014 11:01 AM
Many thanks. PM on its way.
26-02-2014 12:02 PM
