PN website down?
ITWorks
Fixes: 9
PN website down?
I can not get plus.net to load, is it down at the mo?
Seems like others are having the same problem
http://forums.thinkbroadband.com/plusnet/4252495-i-cant-open-pn-website.html
Regards
Mike
5 REPLIES 5
James
Re: PN website down?
Yep - I'm seeing the same.
James
Should be back now.
I saw that, but it was only the "Member Centre" "Help & Support" section that I couldn't get to, whereas the rest of the "Member Centre" seemed to be working fine.  The problem has gone now.
Razer
I guess that's why the forum has just been problematic (assuming it's not the usual problem that's seemingly permanent).
Chris
Legend
Fixes: 169
The forum is hosted on completely separate servers to the portal, so any issues aren't likely to be related.
