PN still using misleading advert for over 6 weeks
- Feedback
- Plusnet Feedback
- Re: PN still adversing landline with evening and w...
31-05-2013 9:14 AM
Come on PN after over 3 weeks since the change, this looks bad and at worst misleading.
Regards
Mike
Re: PN still adversing landline with evening and weekend calls at £ 13.99
31-05-2013 9:17 AM
24-06-2013 9:55 AM
Regards
Mike .
Re: PN still using misleading advert for over 6 weeks
24-06-2013 11:53 AM
24-06-2013 12:10 PM
Thanks for the reply.
Over two month to remove a misleading advert is a long time, obviously not that important to PN.
Regards
Mike
24-06-2013 10:23 PM
drag/drop a new copy of the image into the correct file location on a server or
type copy newimage oldimage?
Seems very poor to me. If this was a "proper" advert; then I'm sure the ASA would be interested and would expect an immediate response to correct it. Now given that this advert can be seen by anybody visiting http://portal.plus.net; I'd be tempted to bring it to the ASA's attention as that might well speed things up a little.
24-06-2013 11:07 PM
Keeping things in a group and rolling fixes together solves all those problems. Obviously there are some times when you have to just get something done, but those times are the exception not the rule.
25-06-2013 12:24 AM
Surely knowing running a misleading ad , would come under you just have to get it done?
You would think after PN had a misleading ad banned not so long ago by the ASA for been misleading,you would think PN would be more careful, obviously not.
Chris If your above post is some kind of defense for the time it takes to remove a misleading ad, i am sure the ASA would not accept that.
Regards
Mike
25-06-2013 1:04 AM
25-06-2013 10:24 PM
Quote from: Chris We have rollout windows and procedures that we follow. It may sound simple but when you've got as many servers as we have, that all need to be kept in sync and then you also need to make sure the staging (used for testing) servers match the live ones exactly otherwise things aren't being tested correctly.
So is a potentially mis-leading advert not something that should be classed as an "exception"?
Saying "sorry - the deal we advertised 30seconds ago is no longer available as of 6 weeks ago" is not likely to go down well with either potential customers or regulatory bodies.
This is the sort of thing that the marketing department should be on top of to ensure consistency. Clearly something was not "in sync" on all of your servers at the time as otherwise this would not have slipped through the net. I would suggest that your testing process needs a thorough review on the marketing side of things.
26-06-2013 9:14 AM
26-06-2013 10:53 AM
Why Do PN think they should be allowed to break advertising rules to fit in with their procedures and timescales ?
The PN response so far is less than satisfactory.
Regards
Mike
26-06-2013 12:34 PM
27-06-2013 2:03 PM
Regards
Mike
27-06-2013 2:13 PM
As far as I know the fix is merged in with the next release already, so splitting it out would cause delays to many other fixes, however we have to balance that against the fact that a small number of people may see this incorrect price (remember that it's only visible for those that log in to the member centre). Having said that, we should get this changed asap and it should have been fixed a lot sooner than it has been.
- Feedback
- Plusnet Feedback
