Overlapping advert on My Portal
DS
Seasoned Champion
Fixes: 22
Sooo, I was navigating around the various tabs available via My Portal...
....and https://www.plus.net/my.html?action=view_transactions&s=0 shows an advert for your mobile offerings, but it's overlapping the text behind it:
The previous time I looked, which admittedly was about a month ago, the banner was further up the page!!Huh
4 REPLIES 4
Chris
Legend
Fixes: 169
Re: Overlapping advert on My Portal
Very odd, I've just logged in on my account at that page and it's showing on the right hand side, just under the menu.
If you refresh does it fix it?
DS
Seasoned Champion
Fixes: 22
Nope Huh
Browni
Aspiring Hero
Fixes: 60
Snap!
I'm using Palemoon 27.1.2 and a forced refresh doesn't fix it.
Legend
Fixes: 255
Using Waterfox 51.0.1 the ad is where I expect it - at the top RH.
