Open questions
Rod2
Open questions
Is it possible to do this? I want to email a response to a question that has been opened on my sccount.
1 REPLY 1
Re: Open questions
Hi @Rod2
Welcome to the forums
It is not possible to email a reply.
To have access to open questions you need to login to the members centre where you should see any open questions you have https://www.plus.net/member-centre/login
This link https://portal.plus.net/wizard/?p=search should also take you to where you need, but you need to be logged in to the members centre for it to work.
Hope this helps
Dan
