On hold > 100 mins to discuss ongoing BB fault. No progress.
- Feedback
- Plusnet Feedback
- Re: On hold > 100 mins to discuss ongoing BB fault...
12-12-2015 12:25 PM
I have an ongoing broadband service reliability issue, the support ticket for which has been closed.
To re-raise it I've been put on hold for more than 100 mins in total. I actually got as far as speaking to a tech support engineer today at about 11:15. He put me on hold too while getting a test report from the exchange.
The call got disconnected soon after he took me off hold.
No there's still no support ticket to follow.
Rather than go through this again I may as well just cancel the direct debit & find a new provider.
3 REPLIES 3
Re: On hold > 100 mins to discuss ongoing BB fault. No progress.
12-12-2015 3:20 PM
Don't do that. If you cancel the service it will be a new install from your new provider, with consequential delays in getting service reinstated and probably cancellation and activation charges.
What I'd suggest is to re-raise the fault online, if you can do so, and also raise an online complaint to see if someone will take it in hand.
12-12-2015 3:26 PM
to raise the broadband fault again go to https://faults.plus.net
12-12-2015 3:30 PM
To raise the complaint: https://www.plus.net/wizard/?p=wizard&page=22909&wizard_id=38
- Feedback
- Plusnet Feedback
