No usage data still: Sorry, there's nothing to show at the moment.
Gel
Champion
Fixes: 29
6 REPLIES 6
adamwalker
Fixes: 223
Re: No usage data still: Sorry, there's nothing to show at the moment.
Hi Gel,
We're not aware of any issues with that. I've just checked your account and might have spotted an issue.
As a line test that would normally tell me this information isn't returning any results can you check your router config and let me know what the realm is you're connecting to (bit after the @ in the username).
Adam
 Adam Walker
adamwalker
Fixes: 223
Hi Gel,
As I've noticed someone else having a similar problem I thought I'd check on your account again and something I did yesterday hasn't fixed it I'm afraid so I've added your details to problem 73721.
Adam
 Adam Walker
Chris9999
Usage not Showing
For some reason my account will not show usage data all i get is -
This might be because your account is new, or your usage has been reset for a new billing period.
It can take up to 2 hours for your usage to show up - please try again later.
This has been going on since november, I raised a trouble ticket at the start of the month saying it was being looked into but little seems to be happening.
I'm on a new billing month, restared router but still nothing an ideas or when this will be fixed?
Oldjim
Resting Legend
Fixes: 63
Posts merged as it may well be the same problem
adamwalker
Fixes: 223
Thanks Jim, good spot was about to report the post to have that done.
Chris9999 I'm adding your details to problem 73721, sorry about the issue.
 Adam Walker
Chris9999
Further info mine is a freeonline account.
Also I have the fixed ip removed from the account back to dynamic could this be part of the problem.
