New subscriber woes
Origami
New subscriber woes
So PN, you didn't really get off to a great start. Let's hope things improve.
1. Setting-up the contract
I select 14th on the order form (I'm away from home 10th t0 14th).
You send me a message, "we've selected the 10th because it's better".
I call PN, better for whom? Please make it 14th, but PN say oh no no no it's been set at the 10th.
On 9th I plug-in the white router
On 10th a message saying the switch-over is started
Later on 10th the landline is switched
On 11th the broadband switch is starting, hang on PN what's this????
Later on 11th broadband is connected.
2. The router
Get home on 14th and find the router is a pile of junk and switch to a spare router I happen to have.
Dear PN, there was a saying, "the customer comes first". I guess that's not the case these days.
19 REPLIES 19
Fixes: 382
Re: New subscriber woes
@Origami Can't really comment on point 1, but why is the Hub a 'pile of junk'?
Origami
@jab1  Well here goes ....
Cannot manually set WiFi channel numbers, the automated thing selects poorly
Cannot select high numbers on 5GHz WiFi
Cannot name the two WiFi bands separately
Cannot work with my own DNS server
Cannot work with my own DHCP server
The logging doesn't provide anything like enough information
Too many settings either not accessible at all or restricted by the user interface
Fixes: 382
Taking your points in order:
(1) Are you sure you can't manually set them? As I never had a any PN Hubs, I can't confirm /deny this, but I would be surprised.
(2) As above - having used one, no comment.
(3) Why should you need to?
(4) & (5) In what way? - although I doubt many ISP supplied routers are capable of this
(6) From what I have seen, the Hub2 provides extensive logging - what exactly is missing?
(7) Which settings?
@Dan_the_Van Any comments?
Fixes: 579
Assuming were talking about a Hub 2 here
Pretty sure you can , dont have my Hub 2 connected at the moment to check
That's correct. Since 5ghz range is limited , its not normally a problem withadjacent networks
That is correct I'm afraid, but isnt usually a problem
Yes you can, you can change the DNS servers that the Hub supplies to DHCP clients
Yes you can, you can disable the HUb 2's DHCP server and use your own. You need to make sure that your server gives the correct default gateway address ( the Hub 2's )
In what respect ?
Fixes: 382
Thanks @MisterW 👍
Origami
@jab1  The channel selection offers 3 suggestions but you cannot overtype in the channel number box, you can only take one of the suggestions.
Two channel names because of temperamental things that seem to always want to select the wrong band, with different names I can configure them to the 5GHz band.
My prior ISP router (ZyXel) does many things that the hub2 doesn't, even my old Netgear WNDR3700v4 does more.
Logging - boot process and intrusion detection are skimpy and I didn't see (if it is there, then my error) how-to forward syslog to another computer. Unix allows rsyslog to be setup.
Fixes: 382
OK. I'll leave this to @MisterW though - he has much more experience of the kit.
Just one final thought though - you DON'T HAVE TO USE THE SUPPLIED equipment.
Origami
@MisterW I need the 5GHz to go high because of other signals are quite strong and as most people leave them on default then they are on maximum width. As I sit in my upstairs study I can see 8 stacked on 36-48 and because of the construction of my property some of them are stronger than my own signal.
DNS/DHCP there's something odd happening and I haven't time to bung a probe on the LAN. The problems have gone away on my own router.
The majority of my devices are Unix.
Anyway, I do appreciate your comments. If I ever get the time I guess I could put it back but as it's stable now I'll let things be as all this turning things on and off has probably upset the DLM too.
Fixes: 579
I'd have to go and check that, unless anyone else has a Hub 2 running that they could check ?
We do see issues with some devices that are 2.4ghz only. The trick is to temporarily disable the 5ghz, connect the device and then reenable the 5ghz. That usually sorts it out.
Assuming neither of those is 'locked', then there's nothing preventing you using either of those. PN are happy for you to use your own router. I just recommend keeping the Hub 2 as a spare.
What model is the Zyxel ? a VMG 3925-B10C by any chance ?
The WNDR3400 is a router only IIRC. The Hub 2 can be switched to bridge mode to act as a modem if required.
Origami
@MisterW  Yes, you are quite right about the Netgear one. I used to stack it behind the Vodafone THG3000 and did all the tinkering on the Netgear side. The Netgear also has openWRT on it.
RobPN
Fixes: 15
I've never used an ISP supplied router (my Hub2 is still sealed in its shrink-wrapped package), but what do you expect for free from a budget ISP contract?
Presumably the Hub2 serves its basic purpose of getting those who choose it connected to the Internet with a limited amount of bells and whistles thrown in, e.g. WiFi.  There was a time when ISPs didn't supply routers and you had to buy your own, so my expectations wouldn't be too high for a freebie which is why I've always bought my own.
Edit:  typo
Fixes: 579
@Origami in that case , just switch the Hub 2 to bridging mode. Connect the WNDR3400 WAN to a LAN port on the HUb 2 and configure the WNDR3400 WAN for PPPoE with your PLusnet credentials.
Origami
@MisterW  As I think I posted earlier, I have a modem-router plugged in and I'll let things alone for a while now.
I can see 54 down / 14 up which is about right for the distance to the green box.
Fixes: 477
On the Hub 2 you only have the choice on the 2.4GHz band of channels 1, 6 and 11. On the 5Ghz band it's only 36, 40, 44 and 48.
