New Plusnet customer, first impressions
- Feedback
- Plusnet Feedback
- New Plusnet customer, first impressions
- « Previous
- Next »
Re: New Plusnet customer, first impressions
01-10-2010 12:49 PM
03-10-2010 6:02 PM
Cheers,
Lynda~
20-10-2010 9:03 PM
The ADSL continued working at a very decent speed (over 3M synced, about 2M on the speed test things), and everything appears to be as it should.
However, my first problem is a sudden drop in speed (too slow for iplayer), yesterday I think. The speed test says only 0.45M now, although the modem sync still appears to be good, like this:
Connection Speed 3872 kbps 448 kbps
Line Attenuation 54 db 15.5 db
Noise Margin 7 db 18 db
Through a slightly obscure link on your help pages (https://portal.plus.net/my.html?action=data_transfer_speed) I found that my speed is indeed currently "500".
I'm at a bit of a loss as to why this has come down when the sync speed is still good and I don't *think* there have been any reconnects until just now when I've been messing with it. Is there any way to find that sort of information out through the Member Centre?
And is there any better advice than "wait for 3 days" in terms of getting the "plusnet speed" reset (sorry, I don't know the right term for the one on that page)
The BT Speedtest thing gives this:
Quote Download speedachieved during the test was - 396 Kbps
Additional Information:
Your DSL Connection Rate :0 Kbps(DOWN-STREAM), 0 Kbps(UP-STREAM)
IP Profile for your line is - 3000 Kbps
Which is all a bit mystifying.
I'm going to continue with the BT speedtester instructions and see where that leads..
Thanks again!
Evan
20-10-2010 9:05 PM
20-10-2010 9:13 PM
Unfortunately I found that the second step of the BTspeedtest (where you connect as [email protected]) doesn't work - it connects but can't load the second page, looks like there's no DNS server or something.
Perhaps I shouldn't be moaning because even at half a meg it's more stable and faster than what I had from AOL / TalkTalk with an identical setup, but I've been spoilt by 2 megs
20-10-2010 9:36 PM
20-10-2010 11:19 PM
21-10-2010 12:10 PM
You can completely avoid that sort of problem by switching on encryption in your wireless router.
Back to my problem, the speed is still locked down at 0.5M for no apparent reason. I suppose I'll have to raise a support ticket.
21-10-2010 12:51 PM
Welcome to the forum.
What router do you have?
The minimum security you should have is WPA, a lot of people use WEP, but that can be cracked in seconds, and sorry to say some dont use any at all
below are my current locals
21-10-2010 2:19 PM
Can't really complain about that.
- « Previous
- Next »
