New Option 1 offer with 10GB allowance
James
Re: New Option 1 offer with 10GB allowance
Quote from: Gel
On Sunday I had another e mail saying I am on new service, confirming wrongly it had 2gb monthly allowance; assume system generated, and system not updated
about new offer!
Gel,
I think you might have missed my post to you on this yesterday.  I should have fixed the problem, barring the discount will start from next month instead of this, which I'm sorry for.
Gel
Aspiring Champion
Fixes: 29
James, yes I saw it, and assume yesterday's + Net e mail was in response to your effort; seems
the system generated e mail advice to customers, by default quotes 2gb?
James
Yes - Apologies for that.  In order to put you onto the special offer I had to first change your product to BBYW1 Annual (2GB) before applying a bolt on to take you upto 10GB usage.
pierre_pierre
will the same apply in my case, move due 23rd this month?
James
You've already agreed to your discount Peter.
It would be pretty off if we said we'd do it for you and then took it away.
(That means that it'll still happen).
pierre_pierre
no I know I will be getting the change, James what I was referring to was the apparent 2 or 10M glitch
James
You should get an email saying that you've been moved onto the 2GB product, but you should then get a ticket reply saying you've been moved onto the 10GB offering.
The reason for that is because there isn't actually a 10GB product, just a specific component that we have to add.
pierre_pierre
I will keep an eye on it then have had three so far Smiley Wink
godsell4
Still trying BBYW1 and finding the link below taking many 10s of seconds to load .... anyone else?
http://www.tv.com/search.php?type=11&stype=all&tag=search%3Bfrontdoor&qs=fringe
I am on gateway pte-ag2
SW.
3Mb FTTC
Fixes: 1,483
It's not your product, I'm on old prem 1 and using OpenDNS and it's not fully loaded after a minute.
pierre_pierre
the main page loads OK its the results of a search that isnt
paulby
Loading fine here (main page and results in less than 5 secs)
BBYW Pro and pte-ag1
James
5.766s on office fibre connection.
pierre_pierre
quick here this morning
godsell4
Is p2p being rate limited during off-peak periods on BBYW1 at the moment given the Network is in 'Plan B' mode at the moment?
3Mb FTTC
