New Customer having an awful experience
- Feedback
- Plusnet Feedback
- Re: New Customer having an awful experience
22-11-2009 9:45 PM
Hugely disappointed and frustrated. If any new customers are looking...it may be cheap, but don't do it...
22-11-2009 10:49 PM
Martin
23-11-2009 9:12 AM
Sounds like you could have 2 separate issues.
1) Wireless, when you say it's unreliable what do you mean? Have you tried changing channels to see if that improves things?
2) Broadband connection, does it keep dropping the connection or something else. It might help if you post your router stats.
Both of these could be down to a faulty router, do you have a spare one to try or could you borrow one?
24-11-2009 4:42 PM
Sorry to hear of the problems you've had so far. I've just taken a look over your account and can see that you've spoken to one of our faults agents who is sending a new router out to you. Hopefully this will get to the bottom of your issues and we'll be able to show you the ISP we really are going forwards.
26-11-2009 9:40 PM
Adiewoo - thanks for yours. The broadband connection keeps dropping out completely, which obviously drives you nuts. It also struggles to open any file more over 500kb.
In terms of the wireless, have had a new router from Plusnet today, but early tests are same issue. And my laptop works fine at two other locations with wireless. It now just does not connect at all - it cannot find the network?
Not sure how do get router stats?
cheers
26-11-2009 9:53 PM
27-11-2009 10:04 PM
my router stats are below. Am at a loss as to what i can do to!
Wireless Access Point - PlusnetWireless
Configuration
Interface Enabled: Yes
Physical Address: 00:24:17:7B:85:C9
Network Name (SSID): PlusnetWireless
Interface Type: 802.11b/g
Actual Speed: 54 Mbps
Band: 2.4G Hz
Channel Selection: Auto
Region: Europe
Channel: 1
Allow multicast from Broadband Network: Yes
Security
Broadcast Network Name: Yes
Allow New Devices: New stations are allowed (automatically)
Security Mode: WPA-PSK
WPA-PSK Preshared Key: **********
WPA-PSK Encryption: TKIP+AES
WPA-PSK Version: WPA+WPA2
[Moderator's note by Dick (Strat) WPA Key removed for security reasons.
27-11-2009 10:05 PM
27-11-2009 10:11 PM
27-11-2009 11:06 PM
27-11-2009 11:15 PM
I have a Belkin Router that had similar issues with one particular PC (wireless was just not relaible), I found some advice (sorry I can't remember where) that said the 'Auto' channel setting on my model could cause problems when it changed channel so I set it to a fixed channel and the problem disappeared.
Might be worth a shot.
- Feedback
- Plusnet Feedback
