Massive fibre speed slowdown on ptn-ag01 tonight 8 May
tijara33
Fixes: 6
My download speed hit the wall about 30 minutes ago, using ptn-ag01. Down from the low 40s to the low teens. I've done a soft reboot & the speeds have recovered, now on pcl-ag02.
Why does this happen? In simple words please, I'm no compuer genius.  Undecided
4 REPLIES 4
Anotherone
Champion
Fixes: 21
Re: Massive fibre speed slowdown on ptn-ag01 tonight 8 May
Not aware of anything amiss, but whatever it was could be anywhere between you and the www. Have you had any thunder and lightning near you this evening?
Mayfly
All Star
I had a problem yesterday but it picked up last night, then this morning was as bad as ever.
My speed test was between .70Mb/s and my normal 4.9Mb/s. Unfortunately I switched the router off accidentally before I checked what gateway I was on. Shocked
All back to normal now. Fingers crossed it stays that way!
chrispurvey
We had no reported issues, if it happens again could you run a speed test and run further diagnostics.
@Mayfly
You were connected on pcl-ag04 during this time.
tijara33
Fixes: 6
Thanks Chris, I most certainly will. Smiley
