Lousy speeds this morning
- Feedback
- Plusnet Feedback
- Re: Lousy speeds this morning
01-05-2010 11:33 AM
Is anyone else getting poor speeds this morning?
Download speedachieved during the test was - 2069 Kbps
For your connection, the acceptable range of speedsis 1000-99999 Kbps.
Additional Information:
Your DSL Connection Rate :15756 Kbps(DOWN-STREAM), 1075 Kbps(UP-STREAM)
IP Profile for your line is - 13000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 22.38:24.02:53.6 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
5 REPLIES 5
01-05-2010 10:39 PM
No mine is fine........... now I have left PLUSNET!!
I had 16.5 meg download speed at 10 am this morning......
Awsome
Awsome
02-05-2010 7:04 AM
but you must have gone to LLU
02-05-2010 9:03 AM
@glloyd
"poor speed" !!!!!!
I have never had speed like that in all the years I have been with Plusnet ! Yours is 10 times faster than mine !
"poor speed" !!!!!!
02-05-2010 9:21 AM
My speed is fine this morning, about normal for my line.
02-05-2010 9:28 AM
