Lack of support from Plusnet
- Feedback
- Plusnet Feedback
- Re: Lack of support from Plusnet
31-03-2009 7:36 AM
I selected that time period as that's when it gets more active, this evening I'll take one at a later one. At least the errors are not bad and really the only thing that concerns me, being unable to read DMT, is that snyc isn't dropping which means BT aren't interferring with my SNRM!, Jack.
Added Screenshot.
And another.
01-04-2009 10:55 AM
well there's a couple of things not looking so good. First that last DMT shot. Did the plots look like that when you started that particular run, or did it go like that part way through or at the end? What I don't know is whether this is just an issue of DMT interfacing with the router, or whether it is reflecting some odd behaviour possibly due to interference.
The reason for the latter thought brings us to the second thing - the number of RS correctable errors has now gone through the roof - over an order of magnitude greater. It is also several orders greater than we've seen previously. This could ultimately lead to a lot more serious errors, and won't do a lot for efficiency of throughput either
RS correctable errors could be due to bursts of interference, keep an ear on you phone line also be observant for other possible sources.
01-04-2009 1:56 PM
I think yesterday there were problems with my phone because last night I went to make a call and the phone wouldn't function at all, so today I've replaced it.
There were a couple of anomolies I noticed this morning when checking the logs one the Router Loge registered at 10.06 "LCP Down", Ichecked the Netgear Forums and it appears to be a phone problem, it didn't show on the Routerstats logs but later on the RS Logs the Upstream and Downstream figures were juxtaposed! I'll add a screenshot of this, Jack.
I've erased the IP Address.
01-04-2009 3:01 PM
01-04-2009 3:25 PM
Sorry no answer about the last DMT screenshot, tonight I will post 3 fom around 18.00 to 24.00 and check them before I post, Jack.
01-04-2009 8:07 PM
I've on several occasions seen the top two graphs disappear and come back after a few seconds and took it to be a normal occurance.
Anyway here's the first screenshot, Jack.
01-04-2009 8:31 PM
Anyway the latest looks better, but we'll keep an eye on those RS corrected errors.
01-04-2009 10:06 PM
01-04-2009 10:23 PM
02-04-2009 12:05 AM
02-04-2009 10:34 PM
The first shot tonight came out wrong so here's number two, Jack.
03-04-2009 9:29 AM
That doesn't look too bad Jack. I notice it's got very noisy later in the evening the last couple of days. (or is that camera shake )
03-04-2009 12:58 PM
The last one was also blank, wish it was the beer but TT for the last two years !! This is getting a lot more frequent recently but I can't sit and watch for it to happen.
As you say the evenings look noisier at the moment and the days are like a millpond, as my usage is normally morning and early evening, up to 18.00 and again late at night, 23.00-01.00 I miss the really noisy periods
I'll send another set this evening and see what happens, Jack.
03-04-2009 7:58 PM
Here's No. 1.,Jack.
03-04-2009 9:20 PM
