Just Got Up And Running After 4 Weeks
- Feedback
- Plusnet Feedback
- Re: Just Got Up And Running After 4 Weeks
27-07-2013 12:34 AM
I see on the portal there's been some maintenance work being done today but it claimed it was fixed earlier this evening...is this why I lost connection twice tonight ?
Plus I can't connect to youtube to continue watching a vid that was interupted by this...I checked down for everyone or just me and they say youtube is up....grrrrr
(Update: I closed my browser and restarted my usb wireless dongle and I can use youtube again, must've been an ip address issue after the dropped connection)
27-07-2013 1:09 AM
The loss of sync you experienced a short time ago might have been due to SNR margin falling too low making the connection unsustainable, or perhaps error rates have caused DLM to make changes.
27-07-2013 1:22 AM
Nothing has changed apart from a drop in sync speed...interleaving hasn't been turned on thankfully.
I'll do a resync in the morning around 6am when it's very quiet noise wise to see if I can get the sync speed back up.
It's definitely an odd one.
27-07-2013 8:00 AM
Still want to get it back to 95.25 where it was before I fitted the new filter and tried a new cable.
My Plusnet Current Line Speed was very quick to drop last night after the brief dropped connection, bet it's not gonna budge an inch back up now I've synced higher.
27-07-2013 3:30 PM
27-07-2013 5:11 PM
I've updated your profile on our side to match the current BT IP Profile
27-07-2013 6:14 PM
Hi Scott...thanks for that...I see it's went up from 7.5Mb to 7.8Mb where it is now.
Are you sure that's right ?....my sync is practically the same as it was when my Current Line Speed was 8.1Mb before this happened.
Before my sync was 9.191 and my line speed was 8.1Mb....my sync dropped to 8.827 earlier in the week there and my line speed stayed at 8.1Mb til this happened last night.
My sync is now 8.915...surely my line speed should be 8.1Mb.
(Edit: It's ok, I'm gonna try another resync in the morning before everyone gets up when it's quiet noise wise and see if I can get a higher sync)
27-07-2013 8:06 PM
The BT IP profile is currently at 7865, so it might be that it hasn't quite creeped up fully yet (although a higher sync from the morning would not hurt matters....as long as it synced higher!)
27-07-2013 9:49 PM
Here's hoping the resync in the morning is better.
27-07-2013 9:57 PM
28-07-2013 1:24 AM
I've never had drops like this until last night...that's three in 24hrs...my line is always pretty stable.
28-07-2013 6:42 AM
My SNR just before it was 6.7db and it resynced at 8.779....better than it was but not as high as the 8.9 or 9.1 I'd hoped for.
It has been raining hard here for the last few days off and on...it's just been absolutely torrential again for the last few hours, but not sure if that's a factor.
Hmmpf...it's been crazy since Friday night...my errors have been the same as normal and interleaving has been off as it should be...wondering if there's been an issue with Plusnet or at my ESROS exchange.
I'll need my profile nudged up to match the higher sync now.
28-07-2013 6:55 PM
28-07-2013 11:14 PM
29-07-2013 6:11 AM
My SNR just before was 6.2db and it has resynced at 9.283.
It was 9.191 on the 17th but I had a 5 min power cut that dropped it, then the shenanigans since Friday night as mentioned above.
So this is the best it's been for a while...9.525 is the highest it's been but not had that since I installed the new micro filter and tried that high quality RJ11 cable.
With my new sync now being 9.283...would someone please nudge up my profile to match it.
