Is the VMBU playing up
Oldjim
Resting Legend
Fixes: 63
I see that my peak usage for today is still showing as zero and my over night usage is a bit lower than usual
11 REPLIES 11
Fixes: 1,495
Re: Is the VMBU playing up
They've changed the note to say 5 hours behind at some point, which would tie in with this.
Oldjim
Resting Legend
Fixes: 63
actually 4 hours - I wasn't aware of that  Embarrassed
will wait and see
rhohne
This what I noticed back in April
Quote from: rhohne
I have found that VMBU figures lag by 5 hours
Fixes: 386
Same here - Fridays was OK, nothing yesterday or today. Huh
MattyC
Fixes: 46
Did it fix up after the 4 hours? I know that yours is showing as zero now for the same reasons.
Matty
Oldjim
Resting Legend
Fixes: 63
yes it did
Fixes: 386
Matty - mine shows 0 for Sat/Sun and 126kb for off-peak today.
MattyC
Fixes: 46
I'll make note of your account for investigation, jab1.
Thanks for bringing this up.
Matty
randpwar
View my Usage
I assume it's gone belly up as mine is showing zero for the last 4 or 5 days.
Please feel free to move to a more appropriate forum
petecov44
My dad's usage went dead as you know before he changed to fibre. Today he is also on 0.0 but I've been logged in using it also.
My account seems fine.
petecov44
Yes my dads usage has stopped since yesterday. I'm not going to mess about with getting gateways etc it's unlimited and he will probably use around 500GB (compared to 100GB on adsl) and that's nothing for FTTC so who cares.it works that's the only thing to note
Last time I bothered no one seemed to care anyway
