If Plusnet sold cars.................
- Feedback
- Plusnet Feedback
- If Plusnet sold cars.................
13-12-2009 6:22 PM
a) Did not match the advertised Speed
b) Did not match the advertised economy
c) Would barely work in rush hour traffic
d) Cost the same as Ferrari but performed like a Moskvich
e) you hated using.
THis service sucks. I have tried to download files today. My speed is about 30kbps which is nothing like the speeds here http://www.plus.net/support/broadband/speed_guide/download_speeds.shtml
I feel conned to put it mildly.
Re: If Plusnet sold cars.................
13-12-2009 6:28 PM
What account type are you on?
13-12-2009 6:58 PM
13-12-2009 7:02 PM
However his is very capable of helping you with your speed issues if you'll let him.
13-12-2009 7:14 PM
13-12-2009 7:21 PM
Quote from: Strat Jelv is not a Plusnet employee and is therefore unable to provide you with a MAC.
Thank you for pointing that out, I hadn't realised. I have been through all the motions of testing the line etc in the last few weeks. Although I an grateful for the help offered, it won't help my case.
13-12-2009 8:19 PM
Of course. you will have a rant at the showroom staff, and beat your chest, until all the hair falls out.... then along comes a nice man, and says, let`s go for a test run (do the testing procedures Jelv, and others will ask for).... you can either go for a test run, and show the nice man what a load of rubbish you have been conned into, just to rub salt into his wounds.... then on the test run, you find that certain things will take a few minutes of your time, and maybe restore your faith in the car you so dearly wanted to buy in the first place, that you accept his offer to try and help....
Every complaint, against, any product, needs to be investigated by the supplier, in order to establish if there is indeed some fault, and how serious that fault, (or faults) is, can only be determined by a series of tests..... (fortunately for PlusNet customers.... other customers are prepared to spend time and effort to investigate)
The tests, do two things..... 1st they either prove or disprove the fault..... 2nd, they give the owner and the helper an equal baseline of statistics, known to each other, to start the rectification process....
Many people come to this forum, in frustrated mode, and end up being a loyal customer, after being helped, by very knowledgeable customers, and the occasional plusnet staff member (who spend their spare time on the forum)
I know this for a fact.... I have read hundreds of complaints, and have even had a rant myself. though not as bad as some.....
Jelv, Anotherone, and HPsauce, to name three, are customers, and nothing to do with PlusNet Staff levels. their help is given freely, and in their spare time. Anotherone, helped me through a four week period, on a "one to one" basis, and for that I am eternally grateful.... His help and support have been invaluable to me.
so, my frustrated friends..... get it off your chest, then let the above mentioned "guru`s" help you to understand a little more about how to sort out your problems....
everyone has a slightly different problem, but most can be solved by patience and dedication..... and of course that all starts with the "equal baseline of statistics" provided by doing the tests and posting the results in your thread....
13-12-2009 8:25 PM
A thread a few of us gamers were chatting about earlier this year..
13-12-2009 9:07 PM
Your comments are extremely valid, however, I have raised my problems in the Broadband Speed section within the last few weeks (I've only been with Plusnet for less than a month. These were initially replied to by Plusnet staff and then nothing. As you state, there are some knowledgeable and very helpful members. We established that there is no fault. I'm not moaning about the advertised up to 8Mb speed. I accept my speed will be less than 50% of this figure. Surfing is not a problem, my speed tests confirm I get around 3 Mb but my Rapidshare downloads and occasional torrent are clearly being throttled and I get a much lower speed than the 250kbps advertised. If these speeds are based on a percentage of my surfing speed, that would explain why I am losing out not once but twice.
It is not a case of being uncooperative. All I want is a service that will allow me to download reasonable amounts in a timely manner. My total useage with my previous provider never exceeded 60GB in a one month period which includes my business use as I work from home. Cost is not the issue. I would gladly pay extra for a service that matches my requirements but I'm afraid Plusnet seems to be lacking in this respect.
13-12-2009 9:15 PM
Sorry
I am not a gamer nor do I use VOIP (or p2p and usenet for that)
13-12-2009 9:18 PM
13-12-2009 9:23 PM
13-12-2009 9:40 PM
Personally I am on "unlimited", but only have a speed of between 1.2 and 1.4 meg....( my line won`t go better than that) I don`t do gaming, just surfing, and emails.... I watch the occasional Youtube movie, but not Iplayer, so it suits me.... My speed is fairly constant now, after being helped by Anotherone, as I mentioned in my first posting on here...
13-12-2009 9:51 PM
13-12-2009 10:18 PM
I don't blame you for being annoyed when you are not getting the performance you want. I'm not sure if Pro would be more suited to what you want to do, but you can compare the traffic shaping of both packages here -
http://www.kitz.co.uk/isp/plusnet_shaping.htm
Quote from: Pugs I do not want to go through this nonsense again. My speed is 3000kbps, my line is OK, my connection speed is fine ...............
You never came back to my last post in your thread on the Broadband Speed board.
Here are my current stats -
Statistics Downstream Upstream
Line Rate 6816 Kbps 448 Kbps
Noise Margin 7.2 dB 21.0 dB
Line Attenuation 43.0 dB 21.5 dB
Output Power 19.8 dBm 12.3 dBm
My line attenuation is 1dB worse than yours and I have a 6M profile with that line rate (sync speed).
Now if that doesn't convince you that you are not getting the best from your line nothing will! This a separate issue (as I'm sure you are aware) from the abysmal throughput performance. If you are convinced, and would like to pick up your thread on the Broadband Speed board, we'll take if from there.
