IP addresses not UK - Can customers please report any problems here
bobpullen
Fixes: 327
Re: IP addresses not UK - Can customers please report any problems here
Good spot, I'll give them a nudge.
bobpullen
Fixes: 327
Quote from: Bob
Struggling with this one. I've just signed up for a new Paddy Power account from an IP in the same subnet, deposited money into the account and placed a bet without any errors whatsoever Huh
I won the bet Wink
Quote from: thedyes0
Weird... it definitely says it to me, I'll get my friend to re-use his account and see if it's fixed (he did email them telling them it was a British ip)
Whilst checking my account for the outcome of the wager I was encountered with the attached, so you definitely weren't seeing things! I'll get in touch with Paddy Power and see what they have to say.
matthews
Quote from: Bob
Quote from: Bob
I won the bet Wink
Well at least that saves you having to try and submit an expenses claim for gambling!
br1anstorm
Quote from: g1000
My IP is 146.199.x.x
When I go to johnlewis.com it thinks I'm in the USA and asks if I want to deliver there.
Strangely, I've just had exactly the same experience with johnlewis.com.
As this was not the first time a website I visited thought I was in the USA, I knew, fortunately, what the likely reason was.  Way back in January I had posted up a baffled query at http://community.plus.net/forum/index.php/topic,136212.0.html.  Oldjim had redirected me to this thread and explained how to solve the problem (unplug router, wait, get another IP address).
So this time I have simply checked my IP address.  It is currently 146.198.93.147.  According to the listings on www.iplocation.net, most of the geolocation databases show it as being a UK IP address belonging to Infonet.  The database IPligence lists it as "Ipv4 Address Block Not Managed By The Ripe Ncc".  But the database of DB-IP still has it listed as being in the US and located at "California El Segundo Infonet Services Corporation".
I pass on this information in case it helps with the ongoing task of correcting and tidying up these databases.  Now I'm off to unplug my router.....
Anotherone
Champion
Fixes: 21
Unplugging your Modem/router is probably not the best course of action as you appear to be on ADSL. What you might get away with depends on how good your connection is. If you are still using your old Netgear and don't have anything in the GUI that allows you to click Disconnect to drop your PPP Internet session for 30secs and then click Connect, you'd be better pulling the mains plug and leaving it off for 10minutes. If you just unplug it from the line, the exchange DLM could see the loss of sync as a dropped connection, and if you have other issues with your line it could work against you.
br1anstorm
Thanks, Anotherone, for that kind and thoughtful reply.  In fact my earlier post was badly phrased.  When I referred to "unplugging", I did indeed mean unplugging or turning off my router's mains-power supply, NOT unplugging or disconnecting the ADSL (phone line) connection.  To be honest I prefer not to mess with the connection-settings in my Netgear router GUI except in dire emergency.  Pulling the mains plug is a lot simpler and easier!
Incidentally tonight I am on IP address 146.90.82.87, which is listed as definitely belonging to Plusnet and geolocated in UK!
dick:quote
StuartUK35
146.199.x.x  for me....
Puts me in California region, EL Segundo Cheesy (ironically, I was there 2 weeks ago!)
topcat96
Okay, I'm now seeing the IP address of 146.199.xxx.xxx showing up on my system ...
Sad
jelv
Fixes: 10
So?
Is it causing you any issues?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
topcat96
Some geolocation problems yes ... but am sure they'll settle down eventually
jelv
Fixes: 10
You need to post details of the problems you are experiencing so that Bob can contact the sites that are using duff data if required.
hapless
Poxy time out!!!
John Lewis for me last week, ip then was 146.200.130.225, but also Teamviewer that evening.
Vague question, just thowing it out there, trying to connect the dots as Support don't seem to be...
Could the "dodgy" IP range be connected with higher latency and slower speeds?
Currently on 146.199.135.152 connected to pcl-bng04.
Speeds on btw speed test are 37.19 down, 15.31 up and 25ms ping
StuartUK35
yes, the US IP range does cause me an issue...
I like to become Host in MW3, so I can boot cheaters...
Game moves me away from host and picks someone else, with a bad connection, despite my team of 4 or 5 being UK players...
I also pickup a lot of US/Canada and Brazilian players, who just lag...
so yes, it causes an issues...
Playing TitanFall also finds regional players in the US, not Euro Sad
Still on 146.199 now Sad
dgm2015
Re: IP addresses not uk
Quote from: Bob
Quote from: AndyH
Plusnet need to clarify whether they are still using the Infonet IP range (146.198.0.0 - 146.198.255.255) because there was another user reporting this the other day http://community.plus.net/forum/index.php/topic,126149.msg1140225.html#msg1140225 It was my understanding that they were no longer using this range due to the issues with geolocation.
No, we are not using those ranges. We are however using 146.200.0.0/16 which was formerly assigned to Infonet (I think we also have 146.199.0.0/16 but it's not in use yet).
Quote from: AndyH
The issue is that in ARIN's database, the organisation that owns the range is shown as:
Name INFONET Services Corporation
It's a bit of a mish-mash TBH.
Whilst these IP's admittedly caused a lot of headaches when first introduced, the vast majority of Geo-location services are now recognising them as UK-based. If you encounter any problematic sites then we could do with knowing about them. We'd need to know the address of the site you're trying to access, the IP you're assigned and the gateway you're connected to.
In the meantime, I'll query why the ARIN records still reference Infonet.
The introduction of these IP's are nothing to do with cost-cutting BTW Roll_eyes
Further to seeing Bob Pullen's replies regarding the IP range issue and wanted to be made aware of any current issues; the IP addresses are causing issues with Heart Internet related services. My current IP address is 146.199.216.62 and although dynamic, each time I restart the IP stays within the same IP range. IPv4 Address / Gateway is 192.168.1.65.
Are attempts being made by PlusNet to resolve this issue?
bobpullen
Fixes: 327
Quote from: dgm2015
You'll have to elaborate on what the issue is, but yes we'll do our best.
Quote from: StuartUK35
What platform, and does this definitely not happen when assigned IP's outside of thee ranges?
Quote from: g1000
This should now be fixed (it looks good from here). If you've previously been redirected to the US site, you may need to select the UK site to get back to the UK variant, or clear your cookies.
Quote from: hapless
What problems were you having with Teamviewer and how can they be replicated?
Quote from: hapless
No, if you believe you've a problem of that nature, then best start a separate thread (if you haven't already).
The second time happened yesterday when doing a bet for a friend who doesn't have internet or pc/laptop, on the website: paddypower.com it rejected my bet based on my IP being from the USA where gambling is banned.
Still chasing Paddy Power. Thought I was getting somewhere but they've gone quiet on me. I'll reach out to them again.
