IP addresses not UK - Can customers please report any problems here
- Feedback
- Plusnet Feedback
- IP addresses not UK - Can customers please report ...
Re: IP addresses not UK - Can customers please report any problems here
01-03-2018 10:59 AM - edited 01-03-2018 11:01 AM
@njw165006 if you check your IP address using https://www.iplocation.net/ you will see that 4 out of 5 providers show your location as being in the UK, the only which doesn't is using data from nearly a month ago.
Pass that on to Paddy Power.
eta: I type too slow ![]()
01-03-2018 11:36 AM
Advised me to try again over when weather improves over weekend and see if it works
01-03-2018 12:17 PM - edited 01-03-2018 12:19 PM
Just what did they “look at”? Your IP address to see if their system treats it as being in the UK?
Anyone chasing issues such as this needs to ask the supplier to verify that their system treats the specific IP address as being in the UK. Generic questions will get the “it all looks ok to us, no one else is complaining”.
01-03-2018 12:39 PM
I won't have the chance to respond any further to Totesport until this evening and haven't addressed the IP issue with them yet(pardon the pun), but I have already had the "no one else is complaining" line!
01-03-2018 1:40 PM
Geolocation usage by some websites is a bit like relying on your SatNav but never doing the updates?
01-03-2018 2:38 PM - edited 01-03-2018 2:59 PM
*edited - obviously meant Paddy Power not Plusnet..........
01-03-2018 3:08 PM
Try something along the lines of...
My IP address A.B.C.D is located in the UK - where does your system (incorrectly) believe it is?
Who do you use for geolocation data?
When did you last refresh that data?
What are you going to do to rectify your use of incorrect data?
01-03-2018 3:45 PM
That will be very helpful for me as well.
01-03-2018 3:48 PM
Think the guy crapped himself when I put your questions to him....... 🤣
01-03-2018 4:00 PM
This problem has been on going for 2 years to my knowledge, with no end in sight. ![]()
IMO the only solution is to purchase a static IP address from Plusnet -- one off fee of £5.
01-03-2018 4:01 PM
Yea, most people do that in response to carefully crafted informed questions. Leave no hiding places, take no prisoners. ![]()
01-03-2018 4:06 PM
@npr,
It is getting better. The first step is education and getting ownership of the issue in the right place - those who choose to offer geography restricted services not doing so based on correct up to date information.
Fixed IP addresses are only an interim solution, which ought not to be used unless there is a very good reason for needing a fixed IP address ... the pool of them is limited ... which is why the pre-owned ARIN registered addresses have been required.
01-03-2018 7:26 PM
This site shows my location as being in the UK for 3 of the 5, but Not Available for the other 2.
Is it safe to quote my full IP address in my next email to Totesport?
01-03-2018 8:35 PM
No problem giving your IP address to support people, they'll need it to investigate.
01-03-2018 8:39 PM
Thanks Browni
- Feedback
- Plusnet Feedback
