IP addresses not UK - Can customers please report any problems here
Davidspeers
Re: IP addresses not UK - Can customers please report any problems here
Just to update you, this has now been escalated to Betfred's Security (!) dept.
In the meantime, I thought I would try yet another browser and installed the horrible Safari.  This cannot even reach the Totesport website as it comes up with the attached error.  I presume this is related?
Fixes: 236
I would suggest that it is different.
Well done on getting the website owner to own the problem.
Davidspeers
Thanks, but I'm not holding my breath!
Kelly
Fixes: 9
Just chasing this up.  @Davidspeers We should have got you access by now, so our process has failed here.  Hopefully should be sorted soon.
Kelly Dorset
Ex-Plusnet Jobsbody
Kelly
Fixes: 9
Hey All,
We've got in contact with them now.  Hopefully they should resolve soon.
@Davidspeers: You should be able to access them now?
Kelly Dorset
Ex-Plusnet Jobsbody
Davidspeers
I can now, Kelly.  Many thanks for your help.
David
njw165006
Magically this has started to work now although Paddy Power IT have not contacted me so not sure what they did..............
(Will update accordingly if they ever do)
Thanks for assistance guys 😀
Davidspeers
..and I never heard any more from Totesport's IT/Security dept.
staceyd86
anyone else getting this with paddy power app and stuff ?
think it something to do with the i.p address because when i use my mobile data i can get on them,
any info please admin/members
also, i don,t want to be resetting my router everyday just to sort this, if it cant be fixed i would like you to end my contract early
mikelahey
Fixes: 12
Plusnet have a range of internet addresses that used to belong to a USA Company. Some geo-location services used by apps incorrectly identify them as still being in the USA.
It's pot luck which address range you get an address from when your router connects up.
Mav
Fixes: 518
Moderator's note:
Threads merged to keep support in one place.
Forum Moderator and Customer
MauriceC
Resting Legend
Fixes: 17
See post #26 in this thread and follow the responses to see why and what steps you need to take.  Smiley
Kelly
Fixes: 9
I think you were on the list of people we have given a static to until the sites have got their stuff in order.
Kelly Dorset
Ex-Plusnet Jobsbody
Kelly
Fixes: 9
Yep. Will be the same problem. I've sent you over to the team to get a fix workaround done. Sorry!
Kelly Dorset
Ex-Plusnet Jobsbody
Kelly
Fixes: 9
You should be able to access Paddypower now?
Kelly Dorset
Ex-Plusnet Jobsbody
