IP addresses not UK - Can customers please report any problems here
- Feedback
- Plusnet Feedback
- Re: IP addresses not UK - Can customers please rep...
Re: IP addresses not UK - Can customers please report any problems here
22-07-2015 1:01 PM
Quote from: Bob
It shouldn't be too difficult to get on an IP outside of the two affected ranges.
It isn't, but it can be difficult to do that and at the same time avoid gateway / congestion issues we're seeing in the evenings.
Thanks for contacting the data base people, it's good to know at least one of them are updating their records -- shame it will take a few weeks.
I really don't want a permanent static IP, it there not temporary solution plusnet can offer for this issue.
22-07-2015 2:06 PM
Quote from: npr I really don't want a permanent static IP, it there not temporary solution plusnet can offer for this issue.
Not officially, no. I've dropped you a PM.
22-07-2015 3:12 PM
http://community.plus.net/forum/index.php/topic,141827.0.html
22-07-2015 3:24 PM
Re: IP address registered in US
23-07-2015 1:32 PM
Quote from: npr Last night I did some gateway hopping to try and escape the peak time slowdown only to discover this morning that my VOIP phone connection was broken.
It appears the IP I moved to is registered as being in the US which make my VOIP need the full international code preceding a phone number.
https://db-ip.com/146.198.168.1
I don't suppose you're able to raise a ticket with VoipDiscount about this issue are you?
Despite my best efforts, they are insisting that you contact them directly. I've advised them that the issue is best dealt with between me and them, and that I'm happy to replicate the issue if they can add a bit of credit to my own account but they're having none of it
[quote author="VoipDiscount"]Dear Customer,
In order to investigate the case, we will need specific details coming from an account experiencing the issue described above. Please ask your customer to contact us directly, indicating the exact issue and we will check.
Thank you in advance.
Kind regards,
Customer service
If you want to reference the ongoing ticket dialogue I have with them, then my username is 'bobpullen'.
Basically, I've asked them to check how they're geo-locating the following IP ranges to make sure they're all seen as UK-based addresses:
146.198.0.0/16
146.199.0.0/16
146.200.0.0/16
143.159.0.0/16
24-07-2015 3:00 PM
They provided a link to the ARIN whois data so I asked how their geo-location worked (whether they're using a provider or maintaining their own list, it would be odd to rely solely on ARIN whois data). It's at this point that they've just started closing my tickets.
[quote author="VoipDiscount"]The answer to your question can be found in the Help section on the website or was already send to you previously. If this is not sufficient please send us a new helpdesk ticket again and we will try to answer your question within a period of 48 hours.
If I raise another ticket, it simply gets met with the same response
Let's hope they are relying on one of the two geo-location providers you've mentioned (although I have my reservations). If not, then there's not much more I can do I'm afraid
They did suggest you change your location via the desktop software but I informed them that this isn't much use as I suspect you're using dedicated SIP device/software.
24-07-2015 3:58 PM
24-07-2015 5:00 PM
I'll contact voipdiscount and see if I can get a better response and report back.
AFAIK they are just a reseller for betamax so they may not know too much about things, this may explain the poor response you got.
I'll see if I can find a contact for betamax and try them as well.
Yes they do have me registered as being in the UK but that may only apply to the browser based voip, I'm using the voip in my router.
Once my credit with them runs out I will be moving on anyway, but that may take a couple of months.
The problem is my next choice is another betamax reseller.
26-07-2015 1:06 PM
It often takes a company being hit in the wallet before they do anything. Or maybe the negative publicity will be enough.
Maybe you should direct VOIPDiscount to this thread in your help request
27-07-2015 9:22 AM
I've also contacted betamax's support, hopefully they will understand the issue a bit better.
Quote from: jafreer Yes, the one thing I take away from this thread is not to use VOIPDiscount.
You should see my recent plusnet support ticket.
31-07-2015 10:22 AM
Quote from: Bob
Quote from: EnglishMohican I have downloaded the cyberghost software onto my laptop. When I run the programme it puts up a screen with a big yellow button and a map. There is one of the location indicator balloons on the map and a statement "Your real location ..... " and quotes the IP number. As I type, that location is shown as in London so all is ok. On Friday, the location was shown as California.
Replicated that (attached), so I'll try and get in touch with them.
Response from Cyberghost as follows:
[quote author="Cyberghost"]Sorry for the long delay. Indeed, I can confirm that the Database we use is indeed based on Maxmind. The only problem was that it was not updated for some time.
Still, we've created a task for our developers to update it so it will soon be displayed OK.
02-08-2015 4:37 PM
If I upgrade to a fixed IP address is there any guarantee that I will get a genuine traditional UK IP address?
02-08-2015 5:03 PM
02-08-2015 7:41 PM
03-08-2015 9:37 AM
IP2location.com updated their data base on the 31/7/15 and it is now showing some of the 146.199.0.0/16 block as residing in California and some in the UK.
tested here: https://www.iplocation.net/
So some progress made. But it means nothing if the users of these data bases don't update at their end.
Note: I've had no sensible replies from support at voipdiscount and nothing from betamax.
- Feedback
- Plusnet Feedback
