IP addresses not UK - Can customers please report any problems here
- Feedback
- Plusnet Feedback
- Re: IP addresses not UK - Can customers please rep...
IP address registered in US
18-07-2015 4:56 PM
It appears the IP I moved to is registered as being in the US which make my VOIP need the full international code preceding a phone number.
https://db-ip.com/146.198.168.1
One silly problem after another.
Re: IP address registered in US
18-07-2015 7:38 PM
I think the 146.198-200 blocks of IP addresses are particularly difficult because they were originally assigned to ARIN rather than RIPE, and it doesn't appear to be easily possible to transfer them, nor even get rid of the INFONET details. The 146.198. block is the most recent of those to be brought into use.
18-07-2015 8:36 PM
In this case it was only the DB-IP database showing as US, other databases showed the IP as being UK.
Don't know about the rest of the block but if they're all the same it should be easy enough to get it corrected in the DB-IP database.
21-07-2015 1:38 PM
This time it's ok in the dbip data base, it's the IP2Location data base showing it as registered in the US.
Quote IP Address 146.199.11.163
Location United States, California, El Segundo
Latitude & Longitude 33.922235, -118.405515 (33°55'20"N 118°24'20"W)
http://www.ip2location.com
Can someone at Plusnet please look in to getting these IP's registered properly as being based in the UK.
21-07-2015 1:51 PM
What issues are arising from this showing as a US address?
21-07-2015 1:59 PM
Quote from: npr which make my VOIP need the full international code preceding a phone number.
21-07-2015 2:03 PM
@npr Can you let us know the VoIP provider so we can look into it.
21-07-2015 2:33 PM
voip provider is voipdiscount.com which is one of the betamax provider.
In my previous posts I stated the two IP data bases which hold the outdated info, is it not those who need to be contacted with your up to date IP list.
ie:
For IP range 146.99.. it's http://www.ip2location.com who thinks it's registered to US, othere data bases are ok
For IP range 146.98.. it's https://db-ip.com/ who thinks it's registered to US, other data bases are ok.
21-07-2015 2:59 PM
Quote from: npr voip provider is voipdiscount.com which is one of the betamax provider.
Yes, if you're confident that these are the services your VoIP provider is using for geo-location.
It's odd that each of them only seems to have issues with a single range (rather than all of them). I've contacted both anyway, so hopefully it'll be sorted before too long.
It's probably worth a mod merging these posts with the main thread.
Re: IP addresses not UK - Can customers please report any problems here
21-07-2015 3:14 PM
topics merged.
21-07-2015 5:31 PM
This is the location checker I used to identify the above: https://www.iplocation.net/
Just noticed a typo in those two IP addresses -- sorry
Should be 146.199.x.x and 146.198.x.x
21-07-2015 5:48 PM
Quote from: npr No I'm not confident...
Fair enough, I'll drop VoipDiscount a message as well then.
Quote from: npr Just noticed a typo in those two IP addresses -- sorry
Don't worry, I didn't make the same mistake when contacting the geo-location providers
21-07-2015 9:04 PM
Quote from: Bob
You must have younger eyes.
This is really causing me some trouble whenever I'm on either of those IP ranges, and it's happening surprisingly often. I've just had to make 3 gateway hops to get on a uk IP.
Until this gets sorted, is there a chance of getting a temporary static (UK) ip address, it's certainly not something I want permanently otherwise I would order one.
22-07-2015 12:10 AM
22-07-2015 12:13 PM
Quote from: npr This is really causing me some trouble whenever I'm on either of those IP ranges, and it's happening surprisingly often. I've just had to make 3 gateway hops to get on a uk IP.
It shouldn't be too difficult to get on an IP outside of the two affected ranges.
ip2location have replied advising that they'll get things updated. Might take them a few weeks though.
- Feedback
- Plusnet Feedback
