IP addresses not UK - Can customers please report any problems here
- Feedback
- Plusnet Feedback
- Re: IP addresses not UK - Can customers please rep...
Re: IP addresses not UK - Can customers please report any problems here
02-12-2014 2:55 PM
I'll look into it nonetheless, although the information Anotherone has asked you for in the other thread would be helpful?
02-12-2014 3:02 PM
Tracing route to plus.net [212.159.8.2]
over a maximum of 30 hops:
0 [192.168.1.100]
1 192.168.1.1
2 lo0.10.central11.pcl-bng03.plus.net [195.166.130.165]
3 irb.11.PCL-CR02.plus.net [84.93.249.98]
4 ae1.ptw-cr02.plus.net [195.166.129.2]
5 ae2.ptw-cr01.plus.net [195.166.129.4]
6 te9-4.ptn-gw01.plus.net [195.166.129.33]
7 gi5-1.peh-cr02.plus.net [84.93.232.61]
8 po5.peh-cr01.plus.net [84.93.232.16]
9 vlan2657.peh-elb01.plus.net [84.93.232.44]
10 portal.plus.net [212.159.8.2]
Computing statistics for 250 seconds...
Source to Here This Node/Link
Hop RTT Lost/Sent = Pct Lost/Sent = Pct Address
0 [192.168.1.100]
0/ 100 = 0% |
1 1ms 0/ 100 = 0% 0/ 100 = 0% 192.168.1.1
0/ 100 = 0% |
2 32ms 0/ 100 = 0% 0/ 100 = 0% lo0.10.central11.pcl-bng03.plus.ne
t [195.166.130.165]
0/ 100 = 0% |
3 --- 100/ 100 =100% 100/ 100 =100% irb.11.PCL-CR02.plus.net [84.93.24
9.98]
0/ 100 = 0% |
4 36ms 0/ 100 = 0% 0/ 100 = 0% ae1.ptw-cr02.plus.net [195.166.129
.2]
0/ 100 = 0% |
5 36ms 0/ 100 = 0% 0/ 100 = 0% ae2.ptw-cr01.plus.net [195.166.129
.4]
0/ 100 = 0% |
6 33ms 0/ 100 = 0% 0/ 100 = 0% te9-4.ptn-gw01.plus.net [195.166.1
29.33]
0/ 100 = 0% |
7 43ms 0/ 100 = 0% 0/ 100 = 0% gi5-1.peh-cr02.plus.net [84.93.232
.61]
0/ 100 = 0% |
8 43ms 0/ 100 = 0% 0/ 100 = 0% po5.peh-cr01.plus.net [84.93.232.1
6]
0/ 100 = 0% |
9 44ms 0/ 100 = 0% 0/ 100 = 0% vlan2657.peh-elb01.plus.net [84.93
.232.44]
0/ 100 = 0% |
10 46ms 0/ 100 = 0% 0/ 100 = 0% portal.plus.net [212.159.8.2]
Trace complete.
My IP starts 83.216
02-12-2014 3:43 PM
02-12-2014 4:16 PM
Quote from: ListerofSmeg I was informed to mention that after i ran http://usertools.plus.net/@gateway/ I got: Sorry, records show your IP address is not from the Plusnet brand and as such, we cannot detect your gateway
Thanks to Bob for alerting us to the unrecognised range. The problem should now be fixed.
David
16-12-2014 11:06 AM
Is this going to be addressed to prevent it happening?
http://community.plus.net/forum/index.php?topic=134958.new;topicseen#new
16-12-2014 12:50 PM
Quote from: Justin7 Is this going to be addressed to prevent it happening?
Very unlikely in the short term, have a read of the second blockquote from my reply earlier in this thread.
Quote from: Justin7 I have recently been assigned on at least two occasions ip address from the us infonet range. Have changed it now by disconnecting.
Question is, what problems was that causing you? Provided with enough information, we can probably fix them.
22-12-2014 10:12 AM
As I use a anti-cheat tool, it also shows my own IP & Geo Location...
So when I see "United States" as my geo location, and then not finding players, but when players do join, they are from Canada/Brazil/Chile, etc , we end up with rubbish laggy gaming (I am on Fibre).
Not locked onto a US IP for at least 4 weeks now which is good....
23-12-2014 2:05 PM
Quote from: StuartUK35 The problems I picked up from this, was when I act as Host in MW3 (Call of Duty)..
It this on PC? What anti-cheat utility are you using? Could be a tricky one to sort
26-12-2014 7:20 PM
Proxy: No Proxy Detected
City: El Segundo
State/Region: California
Country:`US
ISP: Infonet Services Corporation
Although I haven't noticed any issues as yet I thought the locations had been sorted out now.
29-12-2014 3:57 PM
http://www.whatismyip.com/ may simply be returning the address the IP is registered to (it isn't overly clear), in which case the date is accurate. If you use the lookup functionality on the same site though then you get this:
I believe IP2location are one of the last geo-location services we're trying to get sorted.
30-12-2014 6:32 PM
Any chance someone could have a look please?
30-12-2014 6:37 PM
30-12-2014 6:43 PM
Not too fussed as I'll find something to watch elsewhere, just thought I'd raise it.
31-12-2014 1:27 PM
Let us know if the problems continue and I'll check from my own line when I get the opportunity.
31-12-2014 2:20 PM
- Feedback
- Plusnet Feedback
