Horrible speeds for past 3 weeks! 130kbs! Helpdesk useless!
- Feedback
- Plusnet Feedback
- Horrible speeds for past 3 weeks! 130kbs! Helpdesk...
Re: Horrible speeds for past 3 weeks! 130kbs! Helpdesk useless!
03-03-2010 7:43 PM
dick:quote
03-03-2010 8:09 PM
03-03-2010 8:34 PM
I have reset my router already still no change.
dick:quote
03-03-2010 9:09 PM
03-03-2010 9:24 PM
Telephone number:
011427XXXXX
Phone exchange:
SHEFFIELD
Estimated line speed:
4 - Checked on 2010-01-20 11:56:52
Current line speed:
750
dick:quote
03-03-2010 9:45 PM
Suggest raising a ticket or phoning to ask for the Plusnet Profile be raised to match the IP Profile
Quote Current line speed:
750
03-03-2010 9:46 PM
03-03-2010 9:50 PM
Quote from: Oldjim Suggest raising a ticket or phoning to ask for the Plusnet Profile be raised to match the IP Profile
750
Thank you Jim. I will wait for Mand or a support team member, but if you can flag this up that would be great!
03-03-2010 9:53 PM
Quote from: pierre_pierre theres your answer BT profile 3500 PN profile 750, time to kick some one, but will probably have to be tomorrow Jim can you do a Mods PM to the team
Thank you Pierre! Have asked Jim if he can flag this for 2mrw.
03-03-2010 9:54 PM
03-03-2010 9:56 PM
Quote from: spraxyt 3500kbps is the correct IP Profile for a sync speed of 4128kbps. Does Current line speed in the Member Centre (here) show the same value? If it does I suggest you disconnect from Plusnet then reconnect using your router's WAN interface (no need to re-sync) then try a test at mybroadbandspeed again.
And thank you Sprax for your help! hopefully this will be sorted soon.
jim:green quote fixed mod:end
03-03-2010 9:58 PM
03-03-2010 10:04 PM
03-03-2010 10:07 PM
03-03-2010 10:10 PM
Quote Products and Services Discussion / Broadband Speed / Re: Ridiculously poor speed! on: 28/02/2010, 20:09
Thanks for flagging Gerry however just one minor point. There's a tendency from some of the regulars to flag threads / issues to individual members of the Comms team via PM. Whilst the logic is sound, in practice it can lead to incorrect expectations being set. An individual member of the team could be on leave, other duties or off sick. As such they may not see the PM in a timely manner.
It would be better to perhaps use the report to moderator function so the entire team sees it, or simply wait until a member of staff picks up the thread in working hours. Hopefully you'll understand my reasoning.
Mark
- Feedback
- Plusnet Feedback
