Horrendous experience attempting to change over to Plunet fibreoptic
- Feedback
- Plusnet Feedback
- Horrendous experience attempting to change over to...
28-06-2011 5:14 PM
Re: Horrendous experience attempting to change over to Plunet fibreoptic
28-06-2011 6:07 PM
PlusNet configure their procedures to give a generally good delivery of new services and I've found them willing to react when things go wrong. Not all of their support staff are perfect, but they will escalate when things go wrong. The domestic services are low cost and will be sized/resourced for a best efforts delivery. If you want enhanced support they do offer that as an option. The visiting engineers are part of OpenReach which is another part of BT, they are not directly employed by PlusNet.
If the internet is a critical part of your work, maybe you should have had an alternate connection available during the transfer process? 3G dongles for mobile internet are good for that.
28-06-2011 6:22 PM
Thanks for the advice, though - it's appreciated.
28-06-2011 7:14 PM
28-06-2011 7:54 PM
PN have no more control over Openreach than a non-BT owned ISP does. So if the engineer fails to turn up, as happens far too often, the blame is squarely with BT rather than PN.
All the installation is done on BT lines to BT equipment. I doubt there is any way it can be outsourced to PN or another other ISP/company.
Only BT can install FTTC.
At least, that is my understanding.
28-06-2011 8:15 PM
28-06-2011 9:41 PM
Rule 1 - they should not disconnect your line, it is up to PN to deciie when that should happen
they have had a very large fine for badly charging
and they might have another for slamming customers
28-06-2011 10:13 PM
29-06-2011 3:27 PM
I'm really sorry this didn't go as planned. Basically the fibre and phone orders were placed as a simultaneous provide which should have happened on the 23rd June, however problems with the fibre order meant that this didn't happen. Unfortunately by the time we received the notification it was already too late to place an ADSL order to happen as part of the simultaneous provide, which is what's led to the downtime.
29-06-2011 4:33 PM
If Plusnet cannot meet its promises even owing to circumstances beyond its control then it should not make them, when it is the end user that suffers.
The General FAQ states:
"13. Will I stay online until I'm connected?
Yes, you'll still be able to do all the things you normally do online whilst we switch your broadband (and phone service, if you've chosen Home Phone) over to Plusnet. If you've signed up but not yet given us a MAC Key to move your broadband you'll need contact us with this so we can progress your activation.
Once we've let you know your service is ready you'll need to set up your hardware, activate your broadband connection and log in to your new service. Installation is very straightforward and we have lots of step-by-step setup guides to help you."
This certainly did not happen in my case and from what you say it looks as though the account simply wasn't being monitored so you had no broadband to offer when the fibreoptic failed.
And then to be told by your 'support' representative that it was 'only residential' and therefore should not affect work activity by being down for at least a week was the last straw.
You need to rewrite your FAQ and instruct your operators to tell users that the changeover to Pluset can lead to considerable downtime, and you need to properly train your staff in your terms and conditions so that they do not misinform disconnected customers who then have to get the true state of affairs from the sales departments.
'Sorry' does not get me on line - what would get me on line is some facility for expediting your mistakes, for example by having broadband on standby, which Plusnet does not have. The customer carries the risk.
Matt - it's a mess. Your company could not possibly have made a worse first impression.
29-06-2011 10:01 PM
Ok, so I work in IT, and the best way I've found to avert complete disaster is always plan for a bad outcome, and have contingency in place for it. Always carry spares.
Regardless, the problem you had wasn't good, really wasn't good... but as others have said, PN are often left high and dry by BT Openreach, who they have no choice but to use, and no control over.
Sure they're FAQ shouldn't state something they can't guarantee, but lets take an extra example:
PN do have control, and are sure that you'll not get disconnected, they then say so in the FAQ. At install time, a small meteor takes out the exchange, and so with it your net connection. Is the FAQ right? Nope, you lost your connection.
And no, it wasn't PN's fault either time... but still the FAQ was wrong each time.
So, choice a) Change the FAQ... it'd be quite short - we can't promise anything, or b) Have lots of disclaimers.
I hate reading all the legal weasel words, that turn a sales promise into a nothingness, so I'd rather have a slightly optimistic FAQ and assume others will plan for things they rely on.
29-06-2011 10:46 PM
Matt gave no explanation for the failure which leaves me believing that the Plusnet's management systems, such as they are, are not up to scratch.
I still do not know what went wrong and I have no evidence that Plusnet do either, or that it will not happen again.
The impression I have is that maybe they have over-reached themselves with this product.
Comments Plusnet?
29-06-2011 11:30 PM
However, the stuff that goes on in provisioning, especially when it involves physical work done by engineering staff, with diary dates to meet, has a tendency to go wrong more often than anyone would like. It would be wise to expect potential problems and plan contingencies, and wise (therefore) to have identified such issues to someone signing up. Marketing types don't like this kind of complexity in a sign-up process, and it always ends up being the support staff who get to clean up afterwards.
I too suffered a big FTTC deployment problem caused by BT's side (Openreach or Wholesale), but I took a very different attitude: I understood precisely where the problem lay, and understood how much backing I got from Plusnet staff to help sort the problem out. From that problem, however, I can agree with this:
Quote from: plusnetnoway The probability of failure would appear to be high enough for [...] some contingency planning - for example having expediting enginneers that take less than a week to call out if something goes wrong on call...
My feeling is also that this happens to Openreach too often... and that they should have some form of expedited fixers as a redress. I know they do already allow installations to be expedited - but only after paying serious extra wonga. What is needed here is for Openreach to be persuaded to expedite work when they caused the delay in the first place...
But that won't be enough, because BT Wholesale need to do this too... and then Plusnet.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
29-06-2011 11:51 PM
It is not good enough to blame subcontractors with no other explanation. Plusnet, as the customer facing body, are responsible for understanding, communicating and expediting the issue and as far as I'm concerned they failed each of these three tasks and I have no confidence that they will perform any better next time.
It might help if we could have a fuller explanation from Plusnet on this other than Matt's personal expression of regret. For example, why on earth wasn't I left with Talk Talk until Plusnet had its act together? Why did Plusnet take over my phoneline when they didn't have a proper service to provide?
30-06-2011 4:29 AM
Quote All the installation is done on BT lines to BT equipment. I doubt there is any way it can be outsourced to PN or another other ISP/company.
Correct, Anyone who does without BTs authorisation, is actually tresspassing, and tampering with their network, any issues which arise they would also be accountable for in terms of cost.
Quote why on earth wasn't I left with Talk Talk until Plusnet had its act together? Why did Plusnet take over my phoneline when they didn't have a proper service to provide?
With respect, you'll probably find that TT has ceased the service, rather than doing what they should do - when a MAC is used. (this isnt the first time they've done this, and wont be the last. its probably why so many people do not leave TT).
Quote as I'm concerned they failed each of these three tasks and I have no confidence that they will perform any better next time.
Indeed, but as above - PN do not do anything with the network itself, BT do. PN just pass on the instructions and hope that BT sort it.
Quote No warning was sent that the engineer was not going to turn up
Is a failure of BT to communicate with PN (as they do with any ISP) - it would take PN to call BT (probably offshore :P) to find out why theyre not attending.
Quote However, the internet is not a new technology, and honouring one's commitments is not a new business practice.
Your going onto a product thats been in the market less than 12 months commercially, and what, 2 years on a trial basis?
BT has had to train all their OR staff to ensure that they can do fibre installs, ontop of all the diagnostics etc. which come with the service. Not a small feat.
They've upgraded an over-subscribed, antiquated network to provide customers with a better experience.
I know, its a ballache and a PITA when something goes wrong and leaves you without a connection.. (i'll never forget the PN Tiscali LLU issues i had *years* ago, which left me without service for 2 weeks, and the flakiest service ive ever had..)
However, PN are normally pretty sharp at getting it sorted (even if all they can do is harass BT, and apologise), dependant on how long it takes, recompence is sometimes offered - however for a weeks downtime i wouldnt expect anything. Afterall - it does state that there is a chance you will lose service (as you have acknowledged).
and just a small note: I think your username is quite... rude? when you've come here to make a point/ask for help.
[/My 2p
Regards
Matt
(a happy, 2x PN Fibre product customer)
- Feedback
- Plusnet Feedback
