Home move - I just knew it was going to be trouble!
- Feedback
- Plusnet Feedback
- Home move - I just knew it was going to be trouble...
19-01-2012 12:45 PM
At the moment I can't even place the order with Plusnet because I can't get a simultaneous provide code out of BT who provide my phone at the moment. I'm therefore starting to look at plan B which is to tell BT to sling their hook and get the phone from someone else.
If I do a home move I should be able get a simultaneous provide code from BT, give that to Plusnet and get phone and internet connected the same day. So if I were to cancel BT and order PN Home phone and a home move, could they both go live on the same day? Logically I can't see any difference.
The property we are going to is a rental property standing empty, there is a physical line present and BT have confirmed that it is a stopped line so activating it should be easy.
Re: Home move - I just knew it was going to be trouble!
19-01-2012 5:21 PM
By all means give me a shout when you've raised the ticket to request the move and I'll make sure an experienced member of the provisioning team deals with the order for you.
19-01-2012 5:29 PM
I'm guessing you're not moving in just yet which should give us a bit of time to get the broadband order placed? They should be able to get the phone line started pretty quickly and then renumber it to your current number once that is stopped. A renumber shouldn't have any impact on the broadband service if we activate the broadband servicve before BT renumber it.
The only downside is that BT might charge you for the renumber.
19-01-2012 5:36 PM
Rented house - Dorset
There's no renumber required!
19-01-2012 5:38 PM
25-01-2012 5:43 PM
The system didn't want to do it. First it didn't want to accept a fibre order on the new line. Then, even having ordered the simultaneous provide (eventually), the BB component got rejected later. This too was a "stopped" line - but no-one mentioned the restriction on simultaneous provides.
If I'd known that this was the likely result, then I'd have gone for the phone line a week or 10 days earlier (easy, as the stopped line doesn't need an install visit), and then added the BB. Essentially what the guys are now suggesting...
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
04-02-2012 6:02 PM
On the day at 14:51 I received a text message from BT to say the phone was ready and at 17:02 a text message from Plusnet to say the broadband was ready. It wasn't until the next day I could check it out and confirm all was well.
The official line is that the simultaneous order has to be placed a week before the move date. Given my experience I'd recommend that anyone wanting this should start the process off at least a fortnight before to make sure all is well.
The move I've made is from one 20CN exchange (although it has a WBC date set for July) to another 20CN exchange (with no WBC date), the Max Premium has carried across and although I am using an extension socket with a 2M flat extension lead as well (I know, I know!) I'm still getting a full 8128 sync with a 12db noise margin (better than before) and in nearly 24 hours have only logged 112 fastpath CRC errors. All in all - pretty painless.
* Comments on BT:
1) Taking a week at a time of the year when not a lot of people are moving and the housing market is flat is ridiculous! What's it like at a busy time?
2) Sending a message with a "MAC Code" is pretty bad given that it was a stock message and not one keyed by a droid is pretty bad.
3) We'll ignore the fact that they don't seem to know that the C in MAC stands for Code - plonkers!
If it wasn't for the fact that if the phone is faulty BT provide a free diversion to mobile there's no way they would be my phone provider!
04-02-2012 6:35 PM
Having had 4 house moves in the last 6 years I fully understand the stress of that alone, let alone organising a simultaneous provide. I think I must have been lucky as my last move before last involved a new line as well new number and all went smoothly with the line and new provide all happening on the same day by 11:30
Forum Moderator and Customer
04-02-2012 6:42 PM
Quote from: jelv
* Comments on BT:
Some area of the UK are very busy for Openreach. East Anglia being one.
04-02-2012 8:55 PM
I guess some places are busy. And maybe a few more after tonight's snow.
05-02-2012 10:58 AM
- Feedback
- Plusnet Feedback
