Help no Broadband and Plusnet don't care!
tallandslim
My broadband connection has now been down for 6 days. All I get is e mails which tell me nothing and when I called CS the guy didn't care about my problem and was quite rude to me. It was all going so well, but it looks like i'll be going back to Sky at the first opportunity at whatever cost.
B
11 REPLIES 11
orbrey
Re: Help no Broadband and Plusnet don't care!
Hi tallandslim,
I'm looking at this now for you, sorry about the delay. I'll post back shortly when I've more information.
orbrey
Right, this is now in the hands of our faults team and should be updated shortly. From what I can see we've raised it to BT and they've done some initial tests and remapped the circuit on the RAS though this hasn't helped. We'll be passing it back and should have more information hopefully before the end of the day.
orbrey
I've just checked on this again for you and there's no updates as yet though I can see a couple of touches from BT on the fault so it is still under investigation. I'll let you know as soon as I'm aware of anything.
tallandslim
Thanks for looking, but 7 days without the fault being fixed is taking the Michael a bit.
Can you please tell me how much it would cost me to get out of my contract? I recall
there is the set up fee and modem costs to pay.
James
As things stand, you would need to buy out the remainder of your contract (although those rules are due to change later this month).
Let us get your fault fixed for you - our faults team are trying - BT made some configuration changes yesterday which didn't appear to help.  In all likelihood, if you left now, you would probably take your problem with you.
I'll try and get a further update.
James
BT have identified a fault on your line.  They are going to be "rejumpering" it.
They've said that this will be done either today or Monday.
tallandslim
Thanks James, if only the person that I spoke to on the phone was so informative. I understand that things break down, it's just not knowing the details and time needed to get the fault fixed makes the problem worse.  Maybe I'll stay with Plusnet afterall!
Cheers
tallandslim
Still no Broadband.
tallandslim
STOP PRESS! We have a connection 🙂
reserved
Grin
James
That's excellent news.
I've just raised a new ticket on your account.
