Help and Support - Link to service status fails
- Feedback
- Plusnet Feedback
- Help and Support - Link to service status fails
11-01-2017 2:55 PM
https://www.plus.net/help/ and clicking on Service Status at the bottom gives this in Firefox
But it works in Internet Explorer
This is the failed link https://www.plus.net/supportpages.html?a=2&%2525252525252525253fhelpheader=servicestatus
This is the successful one http://www.plus.net/supportpages.html?a=2&%3fhelpheader=servicestatus
Re: Help and Support - Link to service status fails
11-01-2017 2:58 PM
It was clicking links just like these that got my IP banned click with caution!
11-01-2017 3:02 PM - edited 11-01-2017 3:14 PM
Just a couple of minutes ago I had the same issue.
http://portal.plus.net/supportpages.html?a=2 works.
11-01-2017 3:07 PM - edited 11-01-2017 3:34 PM
These pages (can) contain cyclic redirect code and as a consequence they hammer the servers looking up their own behinds. This then triggers an alarm that for me resulted in a ban! ![]()
11-01-2017 3:37 PM
No reply from @Oldjim yet, maybe he's got himself banned ![]()
11-01-2017 3:44 PM - edited 11-01-2017 5:05 PM
We've a ticket raised on this one and it's being investigated (ref: 96169).
In the interim, I'd suggest against repeated clicks in case you end up on the wrong side of our security systems 😉
PS. If you clear your cookies and avoid any of the mobile pages then I suspect the problem will go away.
11-01-2017 3:46 PM
Plusnet have had a number of these internal routing issues over the years and always seem to struggle in resolving them quickly.
I wonder if some of this cyclic re-routing is the root cause of a number of the recent performance issues?
Maurice
11-01-2017 3:50 PM
11-01-2017 3:57 PM
fwiw - Firefox using noscript -> googleanalytics.com and googletagmanager.com blocked plus ghostery and no problems at all here (unless it's already been fixed....?)
11-01-2017 4:59 PM
@bobpullen wrote:
We've a ticket raised on this one and it's being investigated.
... and once banned it seems it's impossible to get it lifted even though it's Plusnet's fault!
- Feedback
- Plusnet Feedback
